Results 1 to 12 of 12
Thread: Filler metal selection for welding mild steel and 4130 tube
    ER70S2 is the usual TIG rod; 70S6 is a normal MIG wire. You don't need the extra silicon for TIG S/F....Ken M
    Lincoln Power MIG 300
    Everlast 160STH
    Miller DEL 200 welder/genset
    Miller XMT300
    A lot of people use S6 for 4130 because it wets out better from other properties of the silicon besides deoxidizing. In some places it works quite well. I also prefer S2, but mainly because I think it handles out of position welds better. You will find plenty of people that swear by one or the other. Just like some people use 70S2 MIG wire for clean metal welding.
    s2 vs s6 isn't much of a difference. each welder will find what works better for them in different situations. s6 is what i got used to and got good with because almost everything i do has to deal with widely varying metal thicknesses, and i often get stuck with dissimilar alloys being welded together. The wet-out properties and deoxidizing properties of s6 work better for me.
    As far as makeup go, s6 does have like twice the silicon and manganese of s2... but that's only 1% of the total makeup. s2 is 97% iron, and s6 is 96% iron, so for all mechanical intents and purposes they are equal, it's pretty much just the 'puddle characteristics' that differ.
    Spike Customs, Inc.
    Fresno, CA 93727
    ph- 559-549-RIDE(7433)
    -Follow me on twitter!-
  1. Welding 1/8 to 3/16 mild steel with powerarc 140st on 120v ?
    By ridenlow559 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-15-2015, 02:58 AM
  2. TIG - Practicing beads on mild steel, getting a bump at the end
    By seanm in forum General Welding Questions
    Last Post: 02-15-2014, 04:50 PM
  3. My first attempt to use filler metal practice stainless steel
    By Vinhtec in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-25-2012, 02:51 AM
  4. Best filler metal chart, or do you just ask your LWS?
    Last Post: 10-26-2011, 01:23 AM
  5. "Battlebot" Repair (TIG weld 4130 Cr-Mo steel)
    Last Post: 03-07-2011, 10:51 PM
