Thread: 2013 PowerArc 200 ST Dual Voltage
  1. Default 2013 PowerArc 200 ST Dual Voltage
    The all new 2013 POWERARC 200 ST is in fact new . We have taken our POWERARC 200 and fitted it with lift Tig and added Dual Voltage .
    We have also redesigned the PCB board for a cleaner more reliable design
    All Dual voltage units will be supplied with a 110 / 240 v adapter pigtail
    EVERLAST CANADA
    www.everlastwelders.ca
    www.titanwinches.com
    905 637 1637
    Is the POWERARC 200ST going to be sold inside the USA at some point?
    Yes,
    Not sure of the current stock of the 200st, but it will be.
    Quote Originally Posted by joeftw18 View Post
    I believe jean put these on sale on Ebay today with shipping for both Canada and the USA
    EVERLAST CANADA
    905 637 1637
    I already thought it was a very reliable welder! I'm not sure that I've even read any issues on the forums.
    There are very few issues with this welder , however with the redesign of a few months ago with the sensing for. 110v - 220v , the dual voltage on many ( not all yet but working on it ) has been improved p
    Another example with voltage inputs changing with nominal power at you box and then adding longer extension cords ,this could bring in too high a amp draw for some relays on the older versions causing possible problems. In real world use this may never be a issue but if it can be improved then it should be
    Cheers
    EVERLAST CANADA
    905 637 1637
  1. 2013 Powertig 200DX 200 Amp 110/220 Dual Voltage Pulse AC/DC
    Last Post: 09-23-2013, 05:22 PM
  2. NEW 2013 Everlast PowerTIG 200DX AC/DC TIG DUAL VOLTAGE welder
  3. Is there any way to tell if my 185 micro is dual voltage?
    By Justin in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-09-2013, 08:54 PM
  4. 2012 Everlast PowerArc 160STH Dual voltage stick welder
    Last Post: 04-26-2012, 01:57 AM
  5. Everlast PowerArc 160STH Dual voltage
    Last Post: 03-23-2012, 06:12 PM
