Results 1 to 20 of 21
Thread: Galvanized Steel
    Default Galvanized Steel
    Guys I helped a friend out today; he has a fence company. We were welding 6" & 4" galvanize schedule 40 pipe. I started feeling bad on the way home. I am sick as a dog! I have the chills and I'm not running a fever. When I get over this I am getting a respirator!Click image for larger version.
    Sep 2011
    Middleburg Florida
    MILK, NOW!
    I'm guessing you don't smoke? I hate it, but one benefit to smoking is that your cigs start tasting sweet when you're exposed, but before it's enough to really make you feel sick or impact you dramatically. First sweet smoke and I'm off chugging milk. USN shops used to send us on regular smoke breaks, first guy that got a sweet one and we'd all get sent to the galley for a chugging competition.
    Trip Bauer
    Former USN HT
    Everlast 200DX New Model
    Hobart Handler 125 MIG
    Van Norman #12
    Atlas 12" engine lathe
    It's commonly called the "zinc flu" (or "welders flu"). Bad stuff (like stomach flu times 100!)! Whenever you weld anything that's galvanized, you want to grind back at least an inch from your weld area on both sides of the material, if possible. It's still not going to keep all the fumes from gathering, but it helps quite a bit. When you notice a large cloud forming, take a break or turn on a fan. That cloud is the sign of trouble!
    As Trip mentioned, milk helps, but more so if you drink it before welding. A respirator and good ventilation is your best bet for not getting sick. At work I would use an upstream exhaust hood just above the welding table, 2 big fans running nonstop behind me, and my respirator at all times (even when doing general grinding in between welding). There were many times I would weld 7-1/2 hours a day for 3 or 4 days straight, and I ALWAYS got sick regardless of the vudu dance I did beforehand. We would make miles of welding duct, roof curbs, and other misc sheet metal items that were all galvanized.
    That zinc flu is supposed to not effect you long term from what "they" say, but being a stage 3 cancer patient for the last 8 years and having 59 polyps removed from the floor of my stomach last year leads me to believe that everything effects your health! Stay safe and take extra precautions! Better to be safe than sorry!
    Now get better!
    I try to always wear a respirator. And no I don't smoke either. Lungs are hard to replace....
    Everlast PowerTig 200DX
    Everlast Supercut 50P
    Sep 2011
    Middleburg Florida
    I didn't mention, but I'm shopping for a respirator myself. Problem is, no run of the mill respirator will work. I refuse to shave and the multiple certs I had to go through in the Navy and afterwards when working for them have educated me on fit and function. My ONLY choice is a positive pressure system with multiple cartridges. $$$$$$$$$ (I think I have enough of them in there) it's on my list, just below the Uvex Bionic face shield, which was supposed to be this month, but I had to buy rings for my air compressor instead.
    Trip Bauer
    Former USN HT
    Van Norman #12
    Thought you knew better than that.
    Here is your very basic welding respirator. The reason I posted the standard canister one behind it is because I have actually fit that one under my welding helmet without problems (just FYI). Even with the charcoal canisters attached I don't think it's ideal for welding though. The flat faced one in the pic is the welding respirator that my company bought me (the cheapest one they could find after I complained about getting sick all the time). It works okay for what it is and it fits my face well, but as Trip mentioned, you have to have smooth skin for a good seal.
    I have another welding respirator that is really good and expensive as it is not a "disposable" like the one pictured, but for some reason I can't find it at the moment. Any of the positive pressure or "fresh air systems" are ideal, but they can be VERY costly depending on what you want to buy. There are also welding helmets with a built in set of filters, but I have never tried that setup personally.
    With any of my respirators, I like to have multiple filters and pre-filters on hand since I can remove the straps and filters from any mask and "pop" it into the dishwasher at night to sterilize it. They all work pretty well if you use ventilation and leave a door open in the distance (especially when tig welding with a breeze outside). Don't expect a lower grade mask to solve all of the problems though when welding. Continual airflow is the key.
    He does now! It only takes getting sick once (or twice if you're extra stubborn!) to learn that lesson!
    Sep 2011
    Middleburg Florida
    First time I noticed the cig bit, I literally threw away a carton and a half thinking something was wrong with them... I'm sure he knows, the fact he posted indicates that. What's that bit... old enough to know better, still to young to care
    Trip Bauer
    Former USN HT
    Van Norman #12
    Milk coats your stomach and keeps you from vomiting. The reason you vomit is your body is trying to get rid of all the toxins in your body. Your actually better off to vomit, because you would have to quit welding. I've not welded enough galvanized steel at one time to get sick until yesterday. I still feel bad, my lungs feel like I smoked a carton of cigarettes! Today I went and purchased a respirator! It's probably not good to weld anything without some type of protection.
    I never vomited, but I had just about all the other symptoms. I went to bed last night wearing sweat pants and a sweat shirt.
    http://files.aws.org/technical/facts/FACT-25.pdf
    Sep 2011
    Middleburg Florida
    Coats, but absorbs and helps flush it out. I don't remember all the data but I believe it has to do with calcium binding zinc, etc. till your system can process it out.
    Yeah, if you're ill enough to vomit a lot of times it helps (like after a binge on Saturday night) but with the fumes, it's not directly from ingesting, so vomiting isn't going to clear the toxins from an inhaled/absorbed source.
    Trip Bauer
    Former USN HT
    Van Norman #12
    So went back and welded again today. It turns out just about every one has been sick during this project. They made fun of me for wearing a respirator, but I do not care! I welded all day and I am not sick! The particulate filter that goes on the outside of the main cartridge was stopped up by lunch. I thought it was worthy of a pic! My wife could not believe the crap you breath in.Click image for larger version.
    let them laugh, there the dumb asses that must like being sick. I cant believe how dirty my respirator is already with the minimal use it has had. Just think, that #### could be in your lungs!
    I went through the same thing at trade school and work with idiots like that. I used to tell those guys about my grandfather smoking, drinking, and partying for 45 years of his life, only to die at 66 with 3 types of cancer including severe Emphysema!
    I would then point out that they did all of that AND welded over toxic coatings on a regular basis too! They would respond by saying "That won't be me", and I'd respond with "Yeah, but good news...If it is, your children and grand kids won't smoke, drink, party, or weld without a respirator once they see how you turned out!" That would usually strike a nerve with them.
    ...Now quit showing your wife the dangers of welding! Women tend to worry enough about all the dangerous things men do as it is!
    Sep 2011
    Middleburg Florida
    Screw that, I'm gonna show her this tomorrow... make it easier for me to spend a couple hundred on a positive pressure system (she doesn't want me to shave anymore than I do).
    Trip Bauer
    Former USN HT
    Van Norman #12
    Once you show her, you can't un-show her! Don't come crying to me if she takes away your welder and tries to get you involved in something safer! In all seriousness, a couple hundred bucks to keep your health isn't even a debate in my mind! Go for it and don't think twice! Being deathly ill sucks BIG TIME, so avoid it at all costs!
    I know that if I was to do a lot of welding of galvanized metal I would absolutely invest in a positive flow system ... when welding anything I try to have good ventilation ... heck I probably use more power running my fans as I do my welders lol.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
  18. Default
    This thread really makes me want to go out and spend the 20 bucks on a mask.
    Poewr I-Mig 205P
    Powertig 185
    I ordered these!
    http://www.amazon.com/3M-Respirator-..._bxgy_hi_img_y
    I changed out the large filter's for these filters. These were on all the welding supply sites and are for galvanized. I had to cut my cheapo hood to get the larger filters to fit, but these fit under my other helmets.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Where i work at we dont use galvanized but we use galvanealed and we have the miller fresh air hood ,very expensive but they work great and miller also makes a respirator that fits under welding hood .
    250 ex
    205 mig
    milwaukee grinder
    140e mig
  1. Replies: 18
    Last Post: 05-26-2012, 08:00 PM
  2. Steel Scorpion
    By sprocket in forum Metal Art
    Last Post: 05-08-2012, 07:50 AM
  3. Cold and hot steel????
    Last Post: 04-11-2012, 04:55 AM
  4. Brazing/Soldering Galvanized Sheetmetal - techniques?
    Last Post: 10-03-2011, 10:02 PM
  5. Welding on Galvanized metal
    By performance in forum Welding articles from Professionals (knowledge database)
    Last Post: 04-04-2011, 09:32 AM
