If you look to the right where there is light it looks ok. But a straight on look does looks that way.
We have come a lot way from the title of this thread. Guess the machine is working...
Thanks! I need to get some larger cups before I can add anymore filler. I didn't look very close at them before painting and installing them on my Jeep, but I don't think it had very much undercut or any at all.
The machine is working great now. It's just very different from the Syncrowave I'm used too.
Everlast Powertig200DX
Hobart Handler 210MVP
Dont like the title of this tread![]()
Oleg Gladshteyn
It's just a different machine. Pedals different, torch is different, etc. Just something I need to get used to.
Hopefully this thread catches the eye of someone else that had the same troubles as me, and helps them out. I meant no disgrace by it.
As I read different things on the forum on bad welding problems it usually the operator not the machine. Over the years I have set up machine that the operator said it was junk Tig, Mig and Stick welders and made fairly nice welds with them for what the welder was designed for. Inexpensive ones and expensive ones. I have made bad welds to find out it to be bad gas, gas flow, dirt, rod type, tungsten type, wire type, hydro problems and many other thing but not the welders. Usually the welders work or not.
Powertig 200DX
Lincoln 180c
Hobart Handler 125
and a bunch of other tools
I don't think a title change was really in order, I wasn't bashing the machine or the company at all. I was simply stating the problem I was having in the title. I even said I was impressed by it when I opened it.
