Results 1 to 10 of 10
Thread: Weld bead appearance. How to set up welder?
    Ac balance still confuses me a bit. Since different brands display it differently. So I have my ac balance set at 35% but is that 35% DCEP or DCEN?? My beads have the stacked dime look but are actually extremely smooth and I didn't know if that was because I need more amps, or maybe more DCEN. Maybe its because I'm using 3/32 tungsten and only have 1/16 aluminum fill rod left. I'm starting to think my fill rod is just too small for the welds I'm doing. Maybe with 3/32 or 1/8 fill rod I would get more definition I. My ridges...
    Also DCEP gives more cleaning while DCEN gives more penetration right?
    Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
    Everlast PowerTIG 225LX
    Everlast Power IMIG 200
    Quote Originally Posted by sw2x View Post
    For Everlast, % is DCEP. Bead look is from your technique. Also with only 1/16" filler , that won't chill the puddle down much so you might not get much by way of freeze lines. Automated TIG will have totally smooth beads, as well because there is a constant feed of wire, not dipping. The welds are still just as strong. For things that get polished I will often use a small wire fed constantly to make smooth welds that polish easily. With thicker wire you would get more texture. Whether that is a good thing or not is up to you.
    Yes, DCEP gives more cleaning, and DCEN giver more penetration.
    Sent with smoke signals using an old saddle blanket.
  1. pulse weld bead vs constant bead
    By fullydrooped in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 02-18-2014, 01:20 AM
  2. How to weld TALL weld beads on 1.6mm thick Aluminum Tube?
    Last Post: 10-08-2013, 01:49 PM
  3. Can you weld copper with your TIG welder?
    By joshuab in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-17-2013, 11:54 PM
  4. 256 cutting in and out mid bead
    By tnc110 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-15-2013, 12:09 AM
