Looks like you are headed in the right direction, For being new at this and just starting it looks like you are making very good progress. 12 hours is a lot of hood time and a lot of gas.You will overtime learn some little tricks and things not to do. It just takes time. I tried a little .025 and .030 sheet and had success using the pulse setting seemed like it helped warpage on the thin material. I learned on a 400 amp Lincoln barrel welder when i was 16 ( used to burn 1/4" 7018 36" long rods) and a year later was thrown into the world of mig that everyone then said the welds would not hold. ( we all know how that turned out ) After that an introduction to Heliarc on a giant old linde machine. Later running our plant was mostly .045 solid wire, 1/16" and 5/64" Flux core wire and stick for maintenance.
PowerTig 200DX
Supercut 50P
Millermatic 200
Jet 1340 Lathe
Jet 20" Drill Press
Jet 12" Wet Band Saw
Kalamazoo H7 Bandsaw
Forward 12,000 lb 4 Post Lift
