Results 1 to 8 of 8
Thread: My First Socket Weld
    Default My First Socket Weld
    I was changing valve covers tonight on a 03 ranger 4.0 sohc and needed an 8mm deepwell socket to remove half the bolts because they have a stud in the center.
    I didn't have one and I couldn't go to the store on thanksgiving so I improvised by grinding the chrome of the area to be welded on two BS brand sockets, butted them up in the cross slide vice and fused them together with the PP256.
    Worked perfectly... it'll never see much torque so I'm not worried about it breaking. 3/32 blue tungsten, 50 amps set on the panel and gave it full pedal to start the puddle then backed off to about 40 to weld.
ID:	8554 I know this isn't a "socket" weld Name:  hehee[1].gif
    Nice. Not sure what steel they make the sockets out of, but sounds like once the chrome was off, you were off to the races!
    Cheers
    Mike
    Looks good. Now you can either add that back to the "specialty" tool section in your tool box or take it back and exchange them for two new ones depending on the warranty.
    2013 PT-200DX
    Ryobi Drill Press
    8" Shear
    6" Bench Grinder
    4x8 CNC Plasma Table
    Quote Originally Posted by zedron View Post
    It's harbor freight cheepies, I'll keep it.
    Wow, you even changed your sig to celebrate Thanksgiving!
    Nice "socket weld". Gotta love the fact that you aren't completely out of luck when the stores close. Cheers.
    Ha, Touche.
    2013 PT-200DX
    Ryobi Drill Press
    8" Shear
    6" Bench Grinder
    Even the cheap harbor freight tools are forged steel and weld great. I always keep some cheap tools in my draw to make stuff like that.
    Sep 2011
    Middleburg Florida
    A lot of tools are a chrome vanadium alloy, if I recall correctly, it should weld very similar to chrome moly.
    When I read the subject I almost didn't click it, I had flashbacks and a waking nightmare for a second, thinking back to my certification welds... 1" chrome moly socket, top and bottom, horizontally welded, vertically mounted. 6-8" long piece mounted on a jig at about 5' from the ground (socket hanging below) 5-6" clearance to the fixture above, two sides with maybe 5-6" clearance. Weld, slice longitudinally, sanded, polished, etched. Next round was X-rayed. I don't recall what the setup name was, but I called it 666H(ell) position
    Wow, got cold sweats just typing that... I'll weld HF sockets all day long for free rather than doing that again
    Trip Bauer
    Former USN HT
    Everlast 200DX New Model
    Hobart Handler 125 MIG
    Van Norman #12
    Atlas 12" engine lathe
  1. My very first weld....ever.
    By CharlzO in forum Welding Projects and Pictures
    Last Post: 11-17-2014, 04:18 PM
  2. How to weld TALL weld beads on 1.6mm thick Aluminum Tube?
    Last Post: 10-08-2013, 01:49 PM
  3. Penetration of weld and weld build up?
    Last Post: 07-03-2012, 07:06 AM
  4. iMIG205 spoolgun socket pinout
    Last Post: 02-07-2010, 02:49 PM
