Page 3 of 13 FirstFirst 12345 ... LastLast
Results 41 to 60 of 257
Thread: NEW 2013 EVERLAST PowerTig 255 EXT AC/DC DIGITAL TIG WELDER
  1. #41
    Thanks Oleg,
    As long as you're fine, I'm fine, and I can still use my ext while it's here.
    That's very nice news on the first 500, I'm sure Duncan will keep them on track for a successful North American variant. I also look forward to any pix, specs, or anectodes about this project.
    Will they reprint the front panels to have the model correctly stated as the 255EXT?
    Now here is my last wish for today, since it only has One knob, can we have a nice one, maybe like the 250EX amp knob?
    Okay, now that I've spent all of my wishes for this week, I bid you each good night.
    Jim
    Hey Jim
    Yes for now all guys can use the welders. Finial version will have all correct prints and we working on nubs as well.
    Mark actually found some very nice new nubs that will go on all of our units. 250EXT nightmare will not happen again
    Oleg Gladshteyn
    Oleg, thanks for this news, now it's going to be even harder to wait!
    Jim
    will the new units be similar in looks to what is posted originally in the thread?
  4. #44
    No, this is EU look.
    Ours will be as posted earlier
    Oleg Gladshteyn
  5. #45
    new argon regulator that will come with all ACDC TIG AND ACDC COMBO units
    Oleg Gladshteyn
  6. #46
    Look just like Victor Regulators I have and they work just fine.Click image for larger version.
Name:	My Regulators Victors.jpg
  7. #47
    Looks more like my favorite the TIG MASTER, with the square column instead of round like the Victor. Either way I like this design a lot.
  8. #48
    Looks like all the new machines show improvements in my opinion. I hope they live up to the expectations
    Jason, there are a few surprises more that will be introduced this year. We're still holding a few cards on thing we have been working on. You see those wrapped connections etc? Everything we have been doing in the last few years is coming together as far as quality and cooperation from the factory.
    Now that the new year has started is the release date still pretty much accurate?
  11. #51
    Mark
    Just like when work a Honda when they would tell us about new models and say here is the cake but you can't eat it Ha Ha.
  12. #52
    Looking good... nice move, Oleg!
    Feb 2011
    Fridley, Minnesota
    Default This is good!
    I've been using my 250 EX for little projects here and there, and even though I LOVE the way it performs, I think that this new machine could make it possible for me to do some things that I'm currently unable to do. The ONE feature that really has me bummed is that the AC advanced pulse will only go to 10hz. I've been playing with the pulse settings on the EX, and found that: on 11ga aluminum, getting up to around 120+ hz, and setting the background at about 30% with a base current at 180 amps, the ease at which I can run a bead on say, an outside corner, is MUCH nicer and easier to control than running a straight, non-pulsed 120-130 amps. I'm still a noob at the whole TIG thing, but learning the capabilities of my 250EX at the same time that I'm honing my skills is making the progress toward becoming a better welder progress much faster than when I was using my Linde Ucc-305. I want this new welder simply because it's the latest technology, but I'll survive with the 250EX just fine until A: I can afford the upgrade, and B: the pulse frequency is upped into at LEAST 200 hz on the AC advanced. Bottom line: I want a new one because they're COOL
    ESAB MigMaster 250-borrowed
    Purox OXY/ACETYLENE
  14. #54
    Hooda,
    Having a high pulse frequency isn't the purpose of the advanced pulse. First, a high pulse frequency for this AC/DC thing isn't possible I don't think because it is physically switching sides of the inverter and the output. But on a larger note, the pulse in the advanced mode helps freeze the puddle rapidly on advanced aluminum, while having rapid forward travel, and creating a more "defined" stack of dimes. It's almost like bump welding without the arc going off completely.
    I'll try to make a more detailed video of the pulse soon. We have one up, but the camera was giving some problems. Working on figuring out how to get better shots. If I can get a close up, you'll be able to see how the welder works on advanced better.
  15. #55
    I bet Jody would share some video tips. He doesn't seem like the type that would keep it secret.
  16. #56
    2013-PT255EXT
    So as I keep reading on the forum about the old 250 EXT’s and 2013-255EXT replacement unit, I would like to know more about the memory setting numbers 0 to 9 do? Mainly what it does not do, as in what it does not save?
    If that is available at this time.
  17. #57
    2013-PT255EXT
    The memory setting memorizes everything from tig/stick, power settings, frequencies.... But for myself the logic is so easy to change I just adjust the settings as I work with the 250 EXT. It looks like the 255 EXT logic will be similar and that is a good thing because the 250 EXT is easy to program.
  18. #58
    Also, are there any updates on the testing of the 255 EXT?
  19. #59
    I have been away for a bit and not much seems to have happened. I would also like to have an update on the 255EXT. Oleg stated his target was a March delivery, and March 1st is 3 days away, and no talk that I can see ... Everlast, let's not get too tight lipped as a reaction to the 250EXT experience, part of why people like this company is the openness to it's customers.
    Come on, throw us a bone!
    Cheers,
    Mike
  20. #60
    Cheers,
    Mike
    Mike , you got a refund and at this point 255EXT doesn't really concerns you. I can tell you one thing .. Our 255EXT will be out MUCH sooner then Miller Dynasty 280
    have a good evening
    Oleg Gladshteyn
  1. NEW 2013 EVERLAST PowerITig 200T DC DIGITAL PULSE TIG WELDER LOW 2AMP START !
    Last Post: 04-12-2016, 09:15 PM
  2. NEW 2013 Everlast PowerTIG 200DX AC/DC TIG DUAL VOLTAGE welder
    Last Post: 03-04-2013, 03:23 AM
  3. NEW 2013 Everlast PowerMIG 210 and 200 MIG / TIG DIGITAL WELDER
    Last Post: 02-10-2013, 02:13 AM
    Last Post: 12-24-2012, 01:43 AM
