Quote Originally Posted by todmorg View Post
When will there be more details on the 255EXT?
With the return deadline only 10 days away on the 250EXT's, it would be nice to have some information on the 255's before then.
Todd...
Here's what was posted by Mark (Performance/Lugweld) at weldingweb... Source: http://weldingweb.com/showpost.php?p...11&postcount=1 This may be here in another thread, I just haven't seen it.
The new Digital Microprocessor controlled 250 Amp PowerTIG 255 EXT will be here soon with some radical new design and improvements over the previous model. Expected delivery will be in March. The units feature wave form control for AC welding, Advanced AC pulse along with standard AC/DC pulse. It features memory function. It also has excellent starting, with low amp capability for AC and DC. The unit also is slated to have an "easy setup" function which features a good starting point for the user for both AC and DC without having to go through a complicated setup process or give the operator a "recenter" point if the customer needs it. The Stick features Hot start time/current control, along with arc force control. Simplified layout and design makes the unit easy to set up and assess the programmed parameters. One knob control keeps the adjustments simple and intuitive. This unit like the 210EXT feature PowerFactor Correction which improves generator operation and withstands "dirty" power better than ever before. If you have further questions give us a call. Some details are being finalized now and full specs will be available shortly after the first of the new year. This unit is compact and is projected to operate on single phase 240 or 3 phase 240 with a 480V 3 phase option available at customer request.
