Results 1 to 3 of 3
Thread: powerpro 256 water cooler question
  1. Default powerpro 256 water cooler question
    i have bought but not yet received the 256 with the water cooler. i just dawned on me that my shop is not heated and here in indiana we have some serious winters. my question is... will i need to do any winterization or any thing special with the water cooler.
    thanks
    ron
    Quote Originally Posted by bubbas55 View Post
    thanks
    ron
    If it gets below freezing you will need to use coolant to protect from freezing or drain everything. Be aware that because of the high frequency start, you should not use normal automotive anti-freeze. Miller makes a special coolant just for TIG that will do the job for you.
    http://www.millerwelds.com/products/...s.php?m=M16700
    thanks for the feedback... it for sure gets below freezing here sometimes for a whole month... ill check out the miller stuff...
  1. Everlast 250EX and water cooler question...
    By Lucky in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-04-2015, 01:06 AM
  2. Water cooler
    Last Post: 11-12-2011, 09:19 PM
  3. DIY Water Cooler
    Last Post: 06-10-2011, 03:22 AM
  4. Running a powerpro 256 without water
    By haveissues in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 04-20-2011, 07:37 AM
  5. Question about W300 water cooler???
    By DisWeld in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-03-2010, 11:28 PM
