Quote Originally Posted by gree box View Post
I did try the trigger switch and checked the preflow. Same result. When I first turned it on it worked three time on the pedal and with the trigger and then it stopped again and would have to scratch start again. How do you check the points?
Give tech support a call and they will walk you through it. You are basically checking the gap between them with a feeler gauge. There are also some wire connections they will have you check.
