Page 1 of 4 123 ... LastLast
Results 1 to 20 of 65
Thread: coffee table
    Dec 2011
    RUSSIA.Sankt Peterburg
    Default coffee table
    built yesterday,glass (diameter 500 mm thickness 8mm)
ID:	7960Click image for larger version.
ID:	7961Click image for larger version.
ID:	7962Click image for larger version.
    Ruslan
    EVERLAST Power Tig 255 EXT
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    SELCO Genesis 352 pme
    Beautiful table! Always nice to see your creations. Cheers!
    Quote Originally Posted by donor76 View Post
    For a customer, friend or you? What did the glass set you back? Looks like a tinted safety glass. Looks nice as usual, but I think the miniatures might be your new calling
    Very cool! Makes me think I need to add a scroller to my shop ... do you think one of the Harbor Freight jobs would be worth the money?
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
    I would also like to know myself if anyone has and uses one. I have looked at their portable bender and their two optional attachments. Never went for it though. All the 20% off coupon the bury me with.
    They are a number of videos on it, and it only bend solid stock (square and round) but would alow a lot of cool brackets and decorative things too.
    That's what I was thinking ... I get covered up in their coupons as well. Harbor Freight welders are junk but I do use a lot of their other tools ... lol I still have a Chicago Electric TIG/Stick unit ... I may give it to my son.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    Hmmm.... I think we need to hear from Ruslan. I'm wondering if he has a completely unexpected way to achieve his results.
    Dec 2011
    Daveо, I understand your question, but I find it difficult to answer because I do not quite understand what talked Mike and Winky (I did not understand the nature of the conversation, it's hard to answer the question if you do not know what it is about)
    Could you rephrase the question ,I am sorry for not knowledge of your language (I badly studied English at school)
    Ruslan
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    I think DaveO is asking if you make scrolls and bends in the metal with a store bought machine like Winky and I are looking at (harborfreight portable bender; probably not known in Russia), or maybe you make them with your own home made tools.
    My apologies, Ruslan, I did not intend to be vague. Mike R is correct: I am wondering what shop tool or process you used for this. We've been assuming you used scrolling machine, but after seeing your other work I wonder if you have a clever alternative.
    Dec 2011
    Now I understood what was being said and what to ask Daveо
    scroll,as you call it is made by hand, ( needed for manufacturing- gas forge, anvil, power hammer,blacksmith)
    if scrolls to do not very much, then everything is forged by hand, and if you need to produce a lot of scrolls, then built on the conductor which is faster and more accurately you can do scrolls.
    if you are very interested, I can tighten, and take pictures of my conductors, and perhaps the process of manufacturing a scroll.
    Ruslan
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    I have a couple, a smaller us made one, and a HF one.
    Ruslan,
    I think you posted them for me one or someone. But sometime you have to show me twice.
    Mark,
    Does the HF work OK. The portable bender for solid tube/square? Did you buy either attachment? It adds up, but I could always use the bender for things. And HF and 20% off a sale item is hard to beat.
    Side note: Did not make it to fastnal yet, the clamp is working fine. But I might swap everything to the B connector if females are not to expense.
    That would be great ...myself ... Don't have a forge or power hammer but I do have oxy-acetylene and ball peen hammers ... lol
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    Dec 2011
    I have a lot of conductors but mostly I use the two how do scrolls-for example, I made ​​the scroll of the strip (20mm x 4mm)heat the end the strip in a gas forge and with the power hammer we flatten end of strip
    (You can flatten by hand on an anvil, but it is a very long and hard )Then I do Grooves,with a home-made instrument.Here we get a workpiece.Heat the workpiece once again and start hammering on the anvil to give the desired bend our blank (this requires some experience) after the given initial bending workpiece, insert it into the conductor and bend over it to the desired size to us.
    all of the above in pictures-part 1
ID:	7982Click image for larger version.
ID:	7983Click image for larger version.
ID:	7984Click image for larger version.
ID:	7985Click image for larger version.
ID:	7986Click image for larger version.
ID:	7987Click image for larger version.
ID:	7988Click image for larger version.
ID:	7989Click image for larger version.
ID:	7990Click image for larger version.
    Ruslan
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    Dec 2011
    part 2
ID:	7992Click image for larger version.
ID:	7993Click image for larger version.
ID:	7994Click image for larger version.
ID:	7995Click image for larger version.
ID:	7996Click image for larger version.
ID:	7997Click image for larger version.
ID:	7998Click image for larger version.
ID:	7999Click image for larger version.
ID:	8000Click image for larger version.
    Ruslan
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    Dec 2011
    part 3
ID:	8002Click image for larger version.
ID:	8003Click image for larger version.
ID:	8004Click image for larger version.
    the and
    Ruslan
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    спасибо for another lesson! It's always a privilege to see the effort that goes into the final product. During the bend, how hot is the work piece? Have you heated it so it will conform to the conductor, or is the work piece cold?
    Dec 2011
    it all depends on the thickness of the workpiece. thin material can be a cold, and thick workpiece it is necessary to heat up strongly.
    Ruslan
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
  1. 80 on CNC table
    By RibbedGiraff in forum Everlast Plasma Cutters (PAC)
    Last Post: 02-18-2016, 06:57 PM
  2. Ottoman/Coffee Table
    Last Post: 11-12-2012, 06:38 AM
  3. Surface Plate Coffee Table, Project #1, d.fisher
    Last Post: 03-14-2012, 12:53 AM
  4. Surface Plate Coffee Table, Project #1, d.fisher
    Last Post: 02-21-2012, 10:17 PM
  5. A coffee table and bathroom remodel
    By jameswswanson in forum Personal Projects (no welder required)
    Last Post: 04-21-2011, 03:39 PM
