I found the same problem with the manual, The one that comes up on the web site for a SuperCut 50P is the manual for the old Cut 50D machine ,It is the only manual that i can find for the 40 and both 50 machines.
PowerTig 200DX
Supercut 50P
Millermatic 200
Jet 1340 Lathe
Jet 20" Drill Press
Jet 12" Wet Band Saw
Kalamazoo H7 Bandsaw
Forward 12,000 lb 4 Post Lift
Online PDF is also outdated.
This is the manual for the SuperCut AND PowerPlasmas online. Not sure what is coming in the box.
http://www.everlastgenerators.com/do...Plasma%202.pdf
There isn't a brochure for the SuperCut series, other than the comparison chart which they linked from the bottom.
We are working on a long term project to update the entire site...so priority is to maintain what we have making small updates as we can.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
That's what i was looking for , the one i found online was the old style manual same as came in the box, Its downloaded and saved in my system. i am going to try and find some drag tips this week.
Thanks Mark
PowerTig 200DX
Supercut 50P
Millermatic 200
Jet 1340 Lathe
Jet 20" Drill Press
As far as the ceramic cups, should I go with these so I can use the spacer guides:
http://www.river-weld.com/10pcs-5060...064_p7429.html
or these:
http://www.river-weld.com/10pcs-shie...004_p7431.html
I am guessing the only difference is the groove for the spacer?
Everlast PowerTig 200DX
Everlast Supercut 50P
