Results 1 to 7 of 7
Thread: Plug/Wiring Question for PT185
  1. Default Plug/Wiring Question for PT185
    Hi Guys,
    I just received my PT185. I am looking at what I need to do to wire it. It is a dual voltage unit. I currently do not have 220v plug in the garage but will run one in the future. The manual says to use a 6-50p plug. Is this correct for the PT185? When I run the 220v does it need to be on a 50 amp breaker or will 30amp suffice? It looks like the unit will not draw more than 30 amps.
    I was planning to use a 220v plug such as the 6-50p on the unit itself then create or buy a pigtail with a 6-50r to 5-15p.
    Thanks,
    Joe
    120= black hot, white neutral, green ground
    240= black hot, white hot, green ground
    6-50 is the standard plug for welders in the US.
    Quote Originally Posted by JoeA View Post
    Hi Guys,
    6-50 is just what is typically used for welders. Since you have a max inrush of around 20A and running of around 15A you could get away with a 15A or 20A plug, if you want. A 6-15 or 6-20 would be plenty, but if you need to be compatible with other shops, you might want to use the most common plug in your area. A 30 or even 20 amp breaker would be fine. Just be sure to match your wire size to the breaker. If you foresee any future expansion, like a plasma cutter, you might want to run a circuit that is big enough for that, even if you don't need it now.
    You can always make up some pigtails to adapt to other plug sizes you might need. Just be sure of the neutral line when you wire that up. These welders require that the neutral be correct when running on 120V. It's not a bad idea to check an outlet before you use it. I have lost track of how many I've found wired wrong over the years.
    Thanks for the responses. If I use a twist lock on the welder would a 6-30p be correct?
    That would be ok. To be exact you could use:
    L6-15P
    L6-20P
    or L6-30P
    Twist locks are especially nice if you have to use an extension cord.
    I made pig tails for my I-Mig 200 which is dual voltage. Used the L6-30 twist lock style. I used a male end off of the machine and then used female ends for the 120 and 220 pigtails. Just make sure you keep track of which wire goes to which prong and match them for the 120 or 220 setups. I think it is important that the machine had the male end for the twist lock and the pig tail has the female end so that way if you plug in the pig tail before twist locking you don't run the chance of conducting off something if the pig tail had male ends and touched something metal.
    Brandon Raineri
    Everlast PowerPro 205
    Everlast I-Mig 200
    SpeedGlas 9100x
    Milwaukee 14" Dry Cut Saw
    Quote Originally Posted by scootarida1 View Post
    This is exactly what I am planning to do.
  1. 250ex plug question
    By shayno in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-25-2015, 04:49 AM
  2. PP 80S wiring up CNC port question
    By LMironworks in forum Everlast Plasma Cutters (PAC)
    Last Post: 01-03-2014, 11:00 AM
  3. Wiring Question 200dx
    By Rus T1 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-12-2013, 08:19 PM
  4. PU 205 Plug Install Question
    By whipman in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 12-27-2011, 02:50 PM
  5. PM205 L10-50R Plug Wiring
    By jas329 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-13-2010, 06:20 AM
