Just started my water cooler a couple days ago. Got the tank done, the front panel(the picture was taken before I added the power switch), and the plumbing mocked up. I ground the welds off the tank because although it's water tight and doesn't leak, the welds weren't up to my standards on looks. The weld I left on the front was 'OK' seeing as I've only been working with aluminum for about a week. I have to get a pump and heat-exchanger, most likely these will come from ebay as I've seen a few of each on there that I think will handle the job. The valve on the front is a needle valve that bleads off pressure if it should be needed. I'm hoping to have a properly sized pump and not need the valve. What PSI are water-cooled torches supposed to be run at? Flow rate? On with the pictures.
Name:	Front Panel(Small).jpg
