I've just finished wiring the op amp circuit. It is a 1:1 amp circuit (no amplication), but should filter out any frequency over 100 Hz. Hopefully, that will deal with the noise.
I've check the wiring tomorrow and add a couple resistors on some signal lines. I started "cleaning up" the software last night, so once that's finsihed, I can load it up and see how well it does.
On the upper half of the board, the components to the left of center is the voltage divider with filter cap and zener diode overvoltage protection.
On the bottom left corner is the op amp circuit.
The green wires are so the display can be mounted away from the proto board.
Just starting in Aug '10
Hobart Handler 187
Its been slow going.
As the code has grown in complexity, I had to reorganize it and clean it up. That took about half a day, then another half day to fix everything I broke.
I started testing the op amp circuit today and I have to go back and check my construction. I have 2.5 volts coming out with 0 going in. The output voltage should be the same as the input voltage.
Hobart Handler 187
Hobart Handler 187
It's been a while since I posted any updates on the Arduino THC project.
It's taken me a while to get the code working after I screwed it up by "cleaning it up". While I was working on getting it working, I started testing other features I had implemented. Unfortunately, it still isn't working as much as it was before I broke it.
I have usage trackign mostly working (all the parts that I could test). It tracks:
- Pilot arc count (number of times torch was triggered)
- Pierce count (number of times arc good signal was received)
- Usage time on tip (hours, minutes, seconds)
- Cutting voltage set point
In addition to updating the data, it will save it to flash after having been idle (not cutting) for a minute.
I've implemented a state machine to control the THC. The states it has are:
- Disabled (won't pass through "torch on" signals)
- Enabled (allows use of menus and goes to cutting mode on "torch on" signal)
- Cutting (actively cutting and controlling torch height)
- Cruise Control (monitoring cutting voltage and will set cutting voltage to the current value when the button is pushed)
The menu system is working, though not all the features are implemented.
I have the voltage monitoring "sorta working". I'm using the op-amp filter and the software is filtering the voltage readings using a sliding window average of 25 samples total, each taken about every 1 - 3 millisecond (sampled as fast as possible). The voltage value is displayed on the LCD every 25th sample.
It's not the best way to do it, but you can tell how stable the voltage is by how blurred the LCD display is. If it isn't being filtered well, it's just an unreadable blur. I've gotten to the point where it appears to be pretty stable at the 1 volt level (I haven't really been paying attention to the tenth of a volt part). While this may not be the most reliable way to figure out what's going on - it's the best I have right now.
When the pilot arc ignites, I get a good voltage display that is pretty stable. However, when it goes into cutting mode, the display goes to zero - which I'm sure is a software bug. My challenge is to try to figure out how to debug it without a debugger and without a serial port to dump data to (I ordered chips to opto-isolate the serial port, but don't have them yet.)
I'd like to figure out an easy way to debug this without using the CNC system. I could make a box to do it (power supply, switches, LED's and a potentiometer to vary input voltage), but would rather not spend the time. So, if I can't jury rig it, I'll have to do that.
I've also been looking at noise issues. The bulk of the noise is coming from the switching supplies that run the CNC interface, and the stepper controllers. I'm using this to power the Arduino. It's horribly noisy. When disconnecting the interface to the CNC and powering it on its own wall wart - the signal is much cleaner. I should be able to address that once I get the opto-isolators. That will let me use the wall wart and I can isolate the signals to the CNC and for a serial port to collect data.
I hadn't bothered to hook up a common ground yet as I didn't want to destroy anything with a ground loop. I did find that I got rid of a lot of noise by just connecting the chasis of the PC to the old computer chasis holding my motor controllers and power supplies.
I got a new oscilloscope for this project and I still haven't totally figured it out. It appears that some setting I'm changing causes the signal to appear to be much noiser (in spite of the LCD display showing that it appears pretty clean). I haven't figured that out yet.
At this point, I need to:
- debug the "arc good" signal (I'm getting it from the PP50, but not passing it back to the CNC)
- figure out why 0 volts is displayed while cutting
- figure out why it seems to hang every now an then
Then, later this week I should have the parts to opto-isolate the interface to the CNC and a serial interface to the PC.
Hobart Handler 187
After spending all night debugging the THC software and my Mach configuration, and counting countless 1" circles, I got basic THC functionality running.
At one point the hysteresis value I was using was too large and it made it look like the torch was sawing through the metal the way it was going up and down. It's alway more fun when you can laugh at your mistakes.
While it's only the simple case of cutting a circle, it does seem to work. The one problem I've noticed is that Mach was seeing the torch down signal, but didn't appear to be going down past the programmed height for the "touch and go". On the plus side, that probably kept the torch from diving.
I used a THC post processor in Sheetcam, but I think I probaly have a configuration issue with Sheetcam or Mach. That's a problem for another day.
The adventure continues with more work on the hardware and software.......
Hobart Handler 187
Did make your own THC post processor, or did you find one online? That's pretty cool that you have got it working. If you have it cutting 1" circles and they look good, then I would say it's pretty close!
You should post some pics of the circles.
From my experience it seems that the problems I have encountered (so far), it was because sheet cam was not configured properly.
I'm just trying to debug the THC, so I used the "MP 1000-THC" post processor. It used the touch and go, but it just didn't seem to go lower than the set cut height. I'm pretty sure it's the post processor or g-code or Mach. The circles aren't any better than the ones I cut without the THC because it just stayed at the same min height - which was too high.
I've just done an ascii capture of the voltages to look at the variability and my filtering. I want to do a couple more captures to get a better data set. But, I was waiting 500 ms. after "arc good" to start control but based on the one set of sample voltages, it takes until about 600 ms after "arc good" for the voltage to stabilize.
It also looks like my software filter is way too slow. I time I'm averaging over 25 samples (with a sample about every 7 ms). That's way too long. Based on that data, I think a three or four sample average should be good.
Hobart Handler 187
do you have the THC enabled in MACH3? I would think its similar MACH3 setup as the one I use http://www.ebay.com/itm/Proffessiona...item27ccdd2789
Although when I checked max cl mode, mine went nuts!!!!
You will need to give it room to work in, so the minimum height needs to be lower than the expected cutting height. Also be sure if you are using soft limits, that they will also allow the motion you need. I can understand not wanting the torch to slam into the work while you are debugging, but if the THC is going to work it has to have the room to do so. How flat is your test metal, and how well aligned to the X and Y axis? If you know the area you are cutting in is flat, and aligned, you can set your soft limit to around .010" off the plate and know that your torch won't hit it. If that passes then, you could shim up your plate to a slight angle and confirm that the torch can follow it. You could also run with the torch off, and feed your device with a variable power supply to confirm that it behaves as desired.
I do have the THC enabled in Mach. I have the option to follow the torch moves without THC on. All the THC option does is stop the system if the arc is lost.
I looked at the setting link you gave, thanks. I'm good with all the settings. I don't have the MaxNC mode set, that appears to be for mills. I do want to jump on the sheet cam support boards to see what I can learn.
Hobart Handler 187
Ram - I still have a lot to learn about.... Am I right in assuming that the soft limits you refer to are in Mach? I didn't expressly set any.
Is it safe to assume that Mach will never allow the THC to drive the torch lower than programmed in G-code? (That seems to be what I'm seeing.) If that's the case, how do you deal with the time it takes the voltage to stabilize after the pierce? (It looks like it takes about 800 or 900 ms. for the torch voltage to "stabilize" after I get the "arc good" signal.) It seems like if you set the cut height too low, you could strike before the THC cuts in.
Hobart Handler 187
Well, I think I figured it out. Its so obvious its embarassing.
On the mach screen there are DRO's for THC MAX and THC Min. Min is set to .2
I've been so busy watching the torch, oscilliscope and the THC display, I've never really paid attention to the Mach screen. I'll give it a try tomorrow.
Hobart Handler 187
One of the problems I've been having is that the LCD display blurs if values are changing quickly.
I haven't had a chance to put in opto-isolators for the serial port yet. But, I really wanted to get some data out of the THC based on what it was seeing. I realized that if I used a laptop running on a battery, I wouldn't have to worry about ground loops. So, I connected a TTL to USB adapter I got on ebay. I did a cut and captured the voltages. The graph below shows a plot of those values for a cut of of 1" circle.
The blue line is the raw voltage as red from the A/D. It is in counts (it's a 10 bit A/D, so it ranges from 0 to 1023). The red trace is the value after software filtering.
I started capturing voltages when the torch on signal went active. I put a 0 value in when the software had waited 500 ms. after the "arc good" signal went active. The 500 ms. delay doesn't seem like long enough to wait before starting height control.
Using the 500 ms period as a reference, it works out to an average of a sample about every 7 ms.
The software was running pretty slow (I think due to the slower than normal serial library I was using). I expect I can easly ramp the sample rate up higher, though it seems to be doing pretty good at the current rate.
You can tell that the software averaging is too slow. I was doing a sliding window average over 25 samples, so that ends up being a 175 ms average. The voltage is clean enough that I can do a much shorter running average (maybe 3 samples or about 20 ms?).
The op amp filter circuit is filtering well, but I ran a circuit simulation and found that some of the wierd behavior I'm seeing is actually how the circuit works (at 0 V in you get about 1.3 V out and the output won't go higher than 3.7 volts). So, I'm just going to need to play with the voltage divider more to get the cutting voltage in the middle of the op amp's range.
I had taken a class on LTSpice (analog circuit simulator) and it helped me figure out parts of the voltage circuit I didn't understand. It turns out that the 100K resistor on each side of the torch voltage coming out of the CNC adapter reduce a signal in the 110 V range down to the 60 V range. I had though I was cutting at a much lower voltage than is normal, I now know its due to the CNC port resistors.
I'm going to have to write a single post on all the details of the CNC port when I'm done. I've learned a lot of things that I've never seen documented in one place.
Hobart Handler 187
Sounds good. Mach will not let the torch go below the soft limits set in the machine setup. The g-code is not really checked for any other limitations and if you tell it to slam into the part and have no soft limits set, it will go ahead and do that. This is because there are a bunch of ways you can offset the positions, so even the DRO will not be telling you the real position. There are the machine coordinates, and the part coordinates and Mach allows a bunch of other offsets for doing multiple parts or fixture offsets. The soft limits look at the actual machine positions and will trigger an e-stop if you hit them. It is a good practice to set them up as a safety. You can also have hard limit switches, but they only tend to protect X and Y. Safe Z min height is too variable to set with a hardware switch, because it will be different for each thickness of material. At least with a plasma you don't usually have to worry about vices and fixtures. There is a macro in mach that will do the touch off from the plate to set the Z offset and you can have that set as a soft limit at the same time. It would be nice to see that voltage graph with the Z axis position on it as well. I don't understand the time scale, is the 0 at 73 really at 500ms? How long is the entire trace?
Since this isn't yet tied into the PC and Mach, I can't get the Z-axis.
The X axis is the sample number. I think that the 73rd sample was at 500 ms, so I just divided 500 by 73 to get an average 7 ms. sample time. (Now, I'm not sure if that is exactly right, but I have some newer, better captures to analyze.
Hobart Handler 187
I now have the voltage control loop working. It is issuing up and down commands (sometimes). I have a bug somewhere to look into - at one point the data dump says a torch up was requested, but I'm not sure that it was actually signalled to Mach.
This trace is cutting a 1" circle and has an arc-ed lead-in and arc-ed lead-out. The X-axis on the chart shows the sample number. I've labeled the key points with their name and time. The Y axis is volts in analog counts (not volts).
(Sorry for the bad image, I couldn't get a higher res image to upload.)
I'm not sure I understand why the voltage goes up and down as it does after the "Arc Good" signal. I'm guessing that "Arc Good" must come on when the pilot arc ignites so that Mach will start the pierce. But, it that's the case, would the pierce cause it to drop then rise like that?
The interesting thing is at the end. You can see where the torch crossed the kerf from the start of the cut. At 50 ipm the width of the kerf takes about 116 ms. to cross. That means it should be easy to implement "anti-dive" by looking for steep slopes on the voltage changes.
Hobart Handler 187
I just noticed that SheetCAM can do wiggle piercing as well, so you might want to make sure that all that will work as well.
I don't have a way to tie where the torch is at and what it's doing to the voltage capture. That makes it a little harder to figure things out. But, I would think that you wouldn't want to try to do control during the pierce anyway, so wiggle piercing shouldn't make a difference. I don't know for sure, just trying to reason through it.
Hobart Handler 187
