Results 1 to 9 of 9
Thread: Aero bar mounts
    Cool Aero bar mounts
    This was going to have a little welding in it, but I changed my mind. I was going to make it out of half inch and build up the top part with weld, but in the end I just whittled it out of 3/4 stock, instead. These are mounts to attach some areo bars to a pair of bicycles.
    Started with 3/4" x 2" 6061 T-6 extruded bar.
    Carve out one side.
    Flip it and do the other side. Bore the holes and profile the part out.
ID:	7304Click image for larger version.
    Flip again and drill, tap, clearance, and counterbore a couple of holes. Profile the ends round.
    Flip and scoop out the top. Drill and tap a hole.
    Here they are mounted to the bars.
ID:	7308Click image for larger version.
    Test fitted on some handlebar tubing.
ID:	7310Click image for larger version.
    I'll probably give them a nice glass bead blasted finish to smooth out the machining marks. Although first I have to clear some junk away from the bead blast cabinet, and I think fix some air fittings on it. Shop maintenance never ends.
    Nice pieces! Should look even sharper with the blasting done. Thanks for the pics.
    or put in a tumbler and polish
    Nice work... I like projects with machining.
    Nicely done- are you the cyclist? My list of future toys includes "lathe" and "mill" but projects like this move "mill" closer to the top of the list. Do you mind describing your setup?
    They are for my fiancé and I. A lathe is usually the first machine tool, but these days the line between mill and lathe gets blurry. These parts could have been made on either, but I used a mill. Specifically an old Alliant 42VC 2HP varispeed with an Anilam CNC control circa mid 1980's. Due to space issues I had to get rid of my big lathe, so now I have an import 9x20 that does the job. Space is one of the big reasons I'm looking to replace my TIG machine with an Everlast.
    Very nice and clean looking. Did you calculate the weight?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    Nope, I just used a 2D program to draw them out, so no volume calculations. I did try to keep them pretty light, but nothing extreme. They came out to just over 40 grams each, and with stainless hardware just over 60 grams. Actually, until you asked, I didn't even bother to weigh them.
    Very nice. Those machined patterns sure look purdy. That's some pretty thick bar stock you started out with. My wife has been getting me into road biking as well lately. A fun and healthy activity to do together for sure.
  1. 4bt Cummins motor mounts
    By dzljon in forum Other Custom Fabrications
    Last Post: 08-31-2016, 06:14 AM
  2. Anti-roll bar link mounts
    By its_34 in forum On Road Fabrication
    Last Post: 08-17-2013, 04:42 AM
  3. Project 5 Mean Green Contest, SeanMurphy265, Mobile Home Leaf Spring Mounts
    By SeanMurphy265 in forum Heavy Equipment and Commercial Projects
    Last Post: 05-23-2012, 01:26 AM
  4. Shackle mounts
    By roadymi in forum Off Road Fabrication
    Last Post: 09-24-2009, 12:48 AM
