Results 1 to 20 of 35
Thread: Plasma Problems
  1. Default Plasma Problems
    I've been trying to handle this offline, but I have to get some 11 ga steel cut before Monday, so I'm tossing this out to the group to see if it might be a simple problem, maybe something I've overlooked.
    PP256 brand new, can't get plasma to work. Air pressure is OK, electrode and cap are tight. Torch (A81) produces a bright blue/white plasma flame when squeezed in mid air. But when I try to cut 1/8" mild steel I get all kinds of blowback that fouls the cap and very weak cutting. Plasma cut a shallow kerf into the metal, but wouldn't cut through. Today I tried again. Held the torch with roller standoff just off the edge of steel I need to cut (which was grounded back to the PP256 + terminal) and the plasma immediately stopped when it contacted the steel. Repeatedly. And I'm approaching the steel slow and there's less than 1/8" gap between the standoff and the cap on the A81.
    So, first I got very weak cutting action and lots of stuff blown back on the cap. Now no cutting action and the flame goes out as soon as it touches the work. This is my first experience with a plasma torch, so I'm a little clueless.
    Any thoughts?
    Quote Originally Posted by Slartybartfa View Post
    Any thoughts?
    Try to get rid of some obvious questions as those sometimes are the ones that are overlooked.
    All connectors to the plasma unit inserted fully and tight
    Work clamp on clean surface
    Work clamp close to cutter
    Make sure the swirl ring is in the torch head. Goes around the electrode (blown plastic looking ring, not plastic but best way to describe it).
    Did you use the plastic tube with the ball inside to setup the air pressure (I think Duncan found it to be around 72PSI if you want to skip that part)?
    Assuming good dry air, it should be working if you have a good ground. Ground in "+" or workpiece port.
    You have pilot and get close and it blows out now?
    Yes to all, torch is negative, ground clamp positive, etc. However I didn't see any plastic tube with ball in it that came with the torch, so I set it to 72 psi. Argon regulator has one, of course, but compressed air goes directly into air pressure regulator/moisture trap (set at 72 psi).
    I've taken the torch head apart several times while replacing parts and compared the parts with the Trafimet A81 parts diagram and everything's there and assembled properly. I've also read extensively on this forum about common problems folks have had and this one doesn't seem to be like any of the others I've read about. I get a nice blue/white flame, but when it touches the edge of the metal to be cut, it simply goes out, and air continues to flow. Doesn't even try to cut now. Is that flame I'm seeing what you refer to as the pilot or is that the actual cutting flame? Not ever having done this before I'm in the dark.
    Attached are some pics I shot. The shot of the face of the PP256 was taken after I turned off the air compressor, so the amber cut light is not on.
ID:	7232Click image for larger version.
ID:	7233Click image for larger version.
ID:	7234Click image for larger version.
    Cut the air pressure back to around 55 psi and approx 40 amps,,,too much air is not always good,,,move very very slow and steady like a machine,,,watch for a rooster tail of sparks coming from the cut,,,try and keep that spark pattern steady,,,moving too fast will snuff the cut action and make it incomplete as shown in your photo's,,,the pilot arc you describe is as it should be...the cutting will take place when that stream touches the metal attached to the ground/earth clamp..
    Getting a splash back is a sign that you are moving too fast for the cutting action...move slow and steady use a piece of angle iron for a guide until you get the hang of it..on 11 guage you could probably get away with out the stand off,,,just using a drag..
    looks like you are touching work and way to close stand off . i run about a 1/4 inch from work when cutting saves on tip . the stand off you are using is not rite for your torch buy the rite one Click image for larger version.
    that stand off you are using is for a s45 not a a81 torch
    Slarty,
    See the following thread ... if you received a flow gauge it should like like the picture in this thread:
    http://www.everlastgenerators.com/fo...st.php?p=17404
    Also, have you checked the spark gap? I imagine that you wouldn't even get the pilot arc if they were way off, but it is something to look at.
    My A81 standoff looks like the one in Slarty's picture.
    Cheers
    Mike
    Power Pro 256
    I have used them a few times and they work fine (big problem is they eat the heck out of the retainer nozzle rim edge).
    Now, the standoff from Plasmahelpers.com I have to reported back to them (no I get no kick backs on their stuff or the TIG finger). It is the better of all of them I have used, but the threaded rods are too close to the torch head again on the A81.
    I like the s45 torch seems to work great for me .
    A flow gauge came with the argon regulator. But none came with the compressed air moisture separator/pressure regulator, which was shipped without a pressure gauge, too, which Oleg took care of. The A81 standoff is, indeed, the wire one and holds the tip a little more than 1/16" off the work. I also purchased a roller standoff, expecting I'd be making some long cuts in 11 ga steel this weekend, but that didn't happen and I'm all gritty now and my skillsaw is smoking from cutting with the friction blade and I've got to sweep out the shop now, and I'm battling a bad attitude at the moment. I'm sort of done, I'm afraid.
    1/8 or more is better saves on consumables and cuts cleaner 1/16 is to close
    turn the start and end amp knobs to 0 I think the unit is in a ramp up mode and is not applying full amps at the start of the cut.
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    Now I do not know a thing about a plasma cutter... One thing I did notice from your picture... Not sure if it was just a front panel picture of the machine setting idle... The specification on the pp256 says... OK to cut indicator lights up when minimum air pressure is present The light on your machine is NOT on.
    Just my 2 cents...
    Shade tree MIG welder.
    Now a Shade tree TIG welder.
    Just my 2 cents...
    Post #4
    Right. The light's not on because when I took that pic, I had shut off the air, so pressure was low and light was out.
    Upslope and downlope are at 0, and Start amps and End amps are at 100%. Re: distance, Mark L at Everlast said, "Tip should be around 1/16th. You need to bend those stand off to make
    the proper distance. Too far away is as bad as too close."
    Forget about standoff distance at this junture,,,if you have it set to 2T ,,40 amps & 55 psi you can dragcut anything up to 1/8 inch no problem,,,it's a little tougher on tips and it has some dross on the cut,,,but you should be able to do it no problem,,,,just go slow and watch your sparks under the cut,,,the angle on them indicates too fast or slow,,I'm almost convinced it's an operator issue more than a machine issue,,,just takes some practice and a steady hand..give it another go and see if it improves..
    Correct me if I'm wrong, but for thin material like that, if you just held the torch at 1/8" over the metal and pulled the trigger, shouldn't it be able to pierce that? If it does, then the machine is working, if the arc goes out, then something is wrong?
    I'm just trying to take the operator out of the equation for troubleshooting.
    Yes whether you have the standoff on or are just pressing the tip down and then fireing it up you will pierce 1/8 material at those settings, after that move it and you are cutting.
    NO that is WAY too far. Standoff should be less than 1/8" and 1/16" if possible. The standoff is the one that comes with the torch if I remember right. This isn't oxy/acetylene. If you'll read any material related to Plasma, it will tell you keep stand off close for plasma. It lowers dross and reduces kerf...and it will actually reduce the wear on the consumable.
    Having too great of standoff also hinders arc transfer and since it is a CC process can make the voltage spike somewhat on the unit which isn't great for the electronics.
  1. Cnc plasma cutting problems
    By FeddFab in forum Everlast Plasma Cutters (PAC)
    Last Post: 07-28-2013, 11:43 PM
  2. 256 plasma problems
    By Charkilah in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-08-2012, 09:03 PM
  3. Problems with plasma cutter
    By Kodiak in forum Everlast Plasma Cutters (PAC)
    Last Post: 04-11-2012, 07:19 PM
  4. QC problems plasma consumables
    By Timberwolf in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 07-16-2011, 01:56 AM
  5. Problems with Power Plasma 50
    By Mattox in forum Everlast Plasma Cutters (PAC)
    Last Post: 11-02-2010, 05:49 PM
