Results 1 to 9 of 9
Thread: pedal issue is fixed!!! now Im really a tigging!!!
    The only thing I need is a relief valve because this pump will do 170 psi! It will blow out my torch!
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=300728104037
    That pump has a built in relief valve. You just need to adjust it to what you want.
    @ Rodsmachineshop: Thats a good point. I might just use some CLR to flush it out. I have flushed it with water both ways though. I might even get an in-line filter to put right before the torch if I can find the right one.
    @ Rambozo: That is true. Hopefully I can adjust it down to 50 or so psi. It will keep it even simpler.
    Everlast lx225
    Hobart Stickmate LX
    Thermal Arc 400GMS
    10"-22" Grizzly lathe
    i have been using for years best to clean cooling systems cascade dishwashing detergent for cleaning radiators and heater cores
    One of these will give you an extra bit of protection. Especially nice if your water cooler doesn't power on with your welder.
    http://www.ckworldwide.com/fuse_block.htm
    Next torch I get I'll be using one for sure.
  1. Foot Pedal issue. PowerTig 200DX analog
    Last Post: 09-14-2014, 01:32 AM
  2. Yet another TIG Foot Pedal issue
    By bswinn in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-03-2013, 01:02 AM
  3. Foot Pedal Issue
    By Injected65 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-04-2012, 01:40 PM
    Last Post: 01-10-2012, 08:39 PM
  5. Foot pedal issue/tweak.
    By angular in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 03-16-2011, 12:30 AM
