I just purchased an everlasting 250ex. Is it ok to power off after welding, or is there a certain amount of time I should leave it on with the fan running?
 New Member
						New Member
						 Cool down?
 Cool down?
		if its hot outside i leave my 250 run for a few minutes after welding
		Personally, I would. I try to keep my electronics as cool as possible and if I can spare the couple of minutes to allow the fan to run, I do it.
		I'd call it 10 minutes to be on the safe side.
		Like Zoama said 10 minutes. I leave my PP205 on while I clean up and it's turned off right before I put it away.
PowerPro 205
9" South Bend Lathe
Enco Mill/Drill
		I always leave anything with a fan that cuts on/off based on temperature on until the fan shuts off (my MIG welder), my plasma cutter I just let it run for a few minutes after I am done with it, unless I only used it for a very short period. I always leave it on until the air solenoid shuts off air to the torch at a minimum, normally a few minutes longer.
My MIG welder does not have a fan running at all once the cooling fan shuts off, so I shouldn't have any worries with it.
Miller 251 MIG
Racin' Tacoma Build Thread
		I usually base the time I let it run on what I have been doing with the welder. A quick tack or two and I will let it sit for 10-15 seconds and shut it off. If I have been blasting away on some heavy aluminum I might let it run for 5-10 minutes.
Everlast Powertig 200DX
Miller Synchrowave 200
Hobart Handler 210MVP
HTP Microcut 30
		I usually clean up the area, reorganize my tools, etc and then shut the welder off last and pack it up. S/F....Ken M
Lincoln Power MIG 300
Everlast 160STH
Miller DEL 200 welder/genset
Miller XMT300
		Totally by the way- welcome, Essen48183! What's your location, what type of welding are you doing?
		This could kind of be looked at like the duty cycle right? I have had it explained to me that with a 60% duty cycle, you need to let it cool for 40% of the time, so, if you weld solid for 6 minutes, let it cool for 4 minutes. Never hurts to go over that though I am sure.
Miller 251 MIG
		Duty cycle is typically measured in 10 minute blocks, so you have it exactly right. Max weld time is 6 minutes with a 4 minute cool down in any 10 minute period. For example 3 on, 2 off, 3 on, 2 off, etc...
If you go over the duty cycle it is not good on the equipment. Even with protection devices, it's never good to trip them on a regular basis.
		You guys must be pros... I can't weld straight through... I am always stopping and repositioning parts. Cleaning them up and continuing the bead.
I never thought of a cool down time, but I usually don't run the machine that hard. If I run up the power it is not for a very long time, just short bursts. From what I remember I don't think I have ever tripped the thermal cutout.
Shade tree MIG welder.
Now a Shade tree TIG welder.
 Member
						Member
		No-one really does. That's why welders have duty cycles. In theory my LX225 can't weld at 225 straight for 24 hours, but in practice I'm only actually welding half the time (or much less!) If I were a robot welding pipe seams or something like that, well that would be different.
The only time I managed to get a temperature cut out was because I forgot to connect the temperature sensor!
		Duty cycle probably only really comes into play with either really small welders (and people overusing them), or in manufacturing work where they are being used constantly with little downtime.
Miller 251 MIG
