Results 1 to 20 of 38
Thread: Gas Saver set?
    Sep 2011
    Middleburg Florida
    Default Gas Saver set?
    40% saving in gas, is that over a standard tip or standard lens? Do they really weld better? Worth buying?
    Trip Bauer
    Former USN HT
    Everlast 200DX New Model
    Hobart Handler 125 MIG
    Van Norman #12
    Atlas 12" engine lathe
    Are you referring to CK Worldwide's "Gas Saver Front End kit"?
    Sep 2011
    Middleburg Florida
    indeed.
    "Ck Worldwide's Gas Saver™ front-end kit allows the users to save up to 40% of shield gas consumption while providing better shield gas coverage patterns. With better shielding gas coverage patterns the welder can extend the tungsten up to 6 x the diameter of the electrode beyond the edge of the gas cup. (This is achieved in draft free areas using argon gas.)"
    Trip Bauer
    Former USN HT
    Van Norman #12
    I was wondering what the difference is between the standard lens, gas lens and gas saver lens. I want to order a CK 130 amp torch (like Zoama’s) and don’t know the differences in the lens. Anyone have some explanation?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    From what I have learned the standard lens works, but it has air current ripples that dissipate the gas quicker. The gas lens has a screen (or a couple) that act as a filter to smooth out the air currents so the gas comes out like a straight tube. At least until outside air disrupts it. Seems to work better for extending the tip out to see what you are doing better. Also the gas lens take a different ceramic cup.
    Not sure on the gas saver.
    Shade tree MIG welder.
    Now a Shade tree TIG welder.
    Brian thanks for the info. I remember seeing the picture on CK's website with the standard lens and gas lens although I thought it was the gas saver.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    As you might imagine, this has been covered before. Don't forget to search before you post. If you find a relevant thread, post a reply in there as a further question relating to it, rather than create a new thread. This helps keep the forum posts better organized. Thanks
    Check out the below linked threads:
    http://www.everlastgenerators.com/fo.../2603-Gas-lens
    http://www.everlastgenerators.com/fo...-torch-nozzles
    http://www.everlastgenerators.com/fo...clear-gas-cups
    Sep 2011
    Middleburg Florida
    Jake, I did search, several times, got several threads that didn't answer my question. The original question was
    "40% saving in gas, is that over a standard tip or standard lens?"
    So, does the 'gas saver' save over a standard tip or a gas lens?
    Trip Bauer
    Former USN HT
    Van Norman #12
  1. 'Gas saver' for 9 and 29 series
    By BillC in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-03-2016, 07:20 PM
  2. Using gas saver kits by c/k -input-
    By Frank in forum General Welding Questions
    Last Post: 06-29-2014, 03:02 PM
  3. 25' CK26 Torch w/ gas saver kit and Dinse connector
    By Injected65 in forum Buy, Sale or Trade
    Last Post: 04-09-2012, 05:24 PM
  4. Quick time saver tip.
    By A/C Guy in forum Other Custom Fabrications
    Last Post: 03-27-2011, 01:51 PM
