Results 1 to 14 of 14
Thread: Argon/Air Fittihg
  1. Default Argon/Air Fitting
    What kind of fitting (argon/air) is on the end of the tig/plasma torch supplied with the PP 205? Does Everlast sell them, if so how much?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    Anyone with information? Everlast?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    talking about the quick disconnect fitting
    Everlast has them but you'll have to call sales... This place has a minimum order of about $50> http://weldingdirect.com/quicmalfitfo.html
    H i The quick connect fitting are BE-21 MINI ADAPTORS if you do a goggle search you will find an on line store or try hear
    http://www.airlinkcompressors.co.uk/ or this one http://www.beaumanor.com/Home.aspx Hope this helps
    Best Regards Chris
    Thanks for the info I will call Everlast sales and get the pricing. Usually if I order something and the shipping isn't free or they don't do USPS flat rate boxes the shipping (UPS/FedEx) is ridiculous.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    You could always knock some out on your lathe just for fun.
    hey check with a snap on truck or mac or matco there fuel injector cleaning an pressure testers us the same quick disconnect fittings . my snap on injection flush machine used the same fittings i use at my shop
    I got the cost from Everlast for the male (torch end) air/argon fitting for my PP205. The cost is either $8.99 (back?) or $12.99 (front?), the email was not clear to me, but the UPS shipping is going to kill me at $29.54. This is one huge drawback to living in Hawaii.
    Where is Everlast located and has anyone ever picked up anything from them directly? I was thinking that I could get someone to pick up the fitting for me and send it USPS.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    don't know why they don't use USPS so much cheaper and faster . that's what every one on ebay uses for International shipping . that what i use when i sell on my ebay store , i hate ups there are way out there on there shipping on prices
    I agree with Rod ... USPS is great so long as U R shipping something that isn't fragile or heavy ... I've had good luck with the them. You might be able to find someone on E-bay with the fittings you need who can ship USPS.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
    Feb 2012
    I started a thread a while ago trying to find some quick release water or air line fittings and you'll find some links in this thread that might ship USPS.
    http://www.everlastgenerators.com/fo...ine-Connectors
    That's what i did ,after a trip to the city driving around today too 2 welding supply shops not having any fittings, i got to looking in the air fittings bin and a standard brass air fitting is just a little bit larger.I figured what the heck $10.00 and 2 weeks shipping time to get it. I just as well spend some time and make one.Took about 15 minutes on the lathe works fine no leaks.Click image for larger version.
Name:	Gas Fitting1.jpg
ID:	7527Click image for larger version.
Name:	Gas Fitting2.jpg
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
    cbmkr nice work, I think Rambozo suggested doing this. I ordered some fittings and hope they are the correct ones, I will verify later tonight. Everlast has them but the shipping kills me almost 2x the cost of the part. I emailed Sjon from CK Worldwide and they have the fittings part #1006 (ferrule) and #2564 (male plug) people just have to order through their CK dealer.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
  1. 100 PSI argon flo?????
    Last Post: 06-09-2016, 08:51 PM
  2. Why 100% Argon or Argon/CO2 75/25%
    By mdennis in forum General Welding Questions
    Last Post: 08-09-2013, 04:11 AM
  3. Air/Argon
    By ChadP in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 02-09-2013, 09:20 PM
  4. What is 95/5 Argon/Oxygen gas used for???
    Last Post: 03-22-2012, 05:01 PM
  5. ARGON and ARGON/CO2 TANK SIZES
    Last Post: 10-13-2011, 05:19 AM
