Results 1 to 20 of 30
Thread: Welding Nuts
  1. Default Welding Nuts
    Anyone have any tips or tricks to welding nuts to pipe? I'm actually welding 1/4" nuts to 1/2" coupling nuts.
    Last time I put the bolt through the nut tacked and partially welded the nut and the bolt started sticking as the weld was cooling. Barely got it out and had to tap the nut to get another bolt in.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    For starters I would use square nuts. They have a lot more meat on them. Weld them on without a bolt in them and let them cool before putting the bolt in. TIG is the way to go and keep the arc focused on the thicker part and just wash the puddle up to the nut without putting too much heat into it. Also it helps to grind off any zinc plating before you start.
    After you weld the nut start running the bolt through the nut. Sometimes you still have to run a tap through the bolt because of distortion.
    I thread the bolt through, usually just to align the nut with the hole drilled in the base metal. Then I back the bolt out while the nut is still hot and malleable. Seems to work with out needing to tap the nut again.
    So, you did not use any filler? Just washed the base metal onto the nut? I may have to try that, as my welds came out really cold when I used filler. I probably had a hard time getting the heat focused because I was concentrating on jamming the filler in.
    Mike
    Power Pro 256
    I usually use a little filler, but just get the puddle going good on the base metal before steering it towards the nut. Sometimes I use flange nuts, then you can just weld the flange and that's pretty easy, especially for sheet metal. It all depends on what kind of task you're asking of the nut. I'm a big fan of welding nuts onto items that get bolted together, so you can tighten the bolts with one tool. For that application I just need to keep the nut from turning, so a couple of deep tacks will do the job. If you are going to have more strain on the nut, you will prolly want a little more than that. However, if you weld two sides of a square nut, that will probably exceed the strength of the bolt, so welding all around is a bit of overkill. I don't usually have any problem in running a bolt in afterwards. 1/4" is a lil small, so keep a tight arc and watch the heat.
    Thanks for the tips especially the square nut tip and I will be using SS nuts. I am going to see if I can get some if not I will use the standard nuts. I think I will use the bolt to line up the hole, tack it, remove the bolt and then finish the weld. I will use 1/16th tungsten and start the puddle on the coupling nut then flow the puddle into the nut. I’ll post pics of the outcome next weekend.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    don't waste any time backing that bolt out.
    I did this on a jeep. I cut the old ones out and put some new ones back in. The first on I had to run a tap through it, and the second worked perfect. The second nut I turned the bolt up and down several times while it cooled down.
    Now that I think about it, I'm guessing that you are welding the 1/4" nuts to the sides of the coupling nuts, right? So why not just drill and tap the 1/4-20 holes in the coupling nut?
    Welding nuts is fairly easy but you do have to take precautions...but you may only need to weld a side at a time if they are overheating. And also try to find some unfinished nuts if you can. That cadmium coating isn't doing you any favors. A plated bolt will cause issues as well if it is overheated while in the nut. The cadmium will start to cause it to seize to the bolt. One other suggestion is to coat the internal part of threads with anti spatter or Hi temp anti seize compound before you start welding. Be careful not to smear it into the weld area.
    Is that holding the spring shackle? I think with metal that beat and corroded, I'd fishplate the frame section before I'd weld a nut to that questionable frame. S/F....Ken M
    Lincoln Power MIG 300
    Everlast 160STH
    Miller DEL 200 welder/genset
    Miller XMT300
    Rambozo yes I am weldinf the 14/"-20 nuts to the side and I did think about threading the coupling nut. These are SS and the wall is very thin not thick like a zinc plated coupling nut. This is why I decided to weld the nuts on. I'm going to see if I can get some flange nuts locally. I will check the dimensions and see if it will fit on the coupling nuts.
    Mark is there such thing as unfinished SS nuts?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    The better question is; are there such things as finished ones?
    BTW cadmium has not been used on fasteners in many years, but the silver zinc that is used is also no good for welding either, grind it off.
    There is silver zinc in 18-8 SS nuts/bolts? and I should grinf them?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    Nope, they come plain. I guess I should have used the multi quote thing.
    It was a little surface rust. That's actually how it came from the factory. I cut the old ones off and put those in the same place. I think it was a late 70's model jeep.
    I found some SS (18-8) 1/4-20 flange nuts locally. It amazes me how much the prices differ, on place thay are $.50 ea and the other is $16 for 50 ($.32 ea). The SS 1/2-13 coupling nuts are $5.15 ea one place and $2.30 another. Iguess it pays to shop around. The square nuts in stock are $.70 ea, wow way to much so I went with the flanged nuts.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    If I have access I like to use a countersunk screw to hold things, because it will self align to the center of the hole. Otherwise you sometimes have the bolt drag a side and it will be stiff. I couldn't find a 1/4-20 square nut handy, but here is a #10-32 as an example. Two sides are probably stronger than the screw, but if you want, you could do all four. Just let it cool a little in between. Because of thermal expansion and cooling, after this was welded and had cooled, I could spin the screw out with my fingers.
ID:	6963 Click image for larger version.
ID:	6964 Click image for larger version.
  19. Default
    I'm planning on using a bolt to line up the holes and tack two sides of the nuts and see how that goes. I will post pics this weekend.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    How do you like your Evolution Rage 2? I've been cutting a lot of 1/4" tubing and it's getting time to upgrade my HF chop saw.
  1. Help! My 200DX went nuts!
    By rake in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-15-2016, 02:09 AM
  2. New cart design, am I nuts?
    By Trip59 in forum Other Custom Fabrications
    Last Post: 08-03-2012, 04:24 AM
