Results 1 to 20 of 23
Thread: Project 1 from NRM. Category 8: Cooker (Huli Huli Setup)
  1. Default Project 1 from NRM. Category 8: Cooker (Huli Huli Setup)
    Here is my huli huli (huli means to turn/rotate/flip in Hawaiian) setup I have been working on for a while. It has come a long way from the first one I made. I use the large spit to cook pigs (40-65 lbs) and the small spit to cook chickens/roasts. The setup is corrugated metal around the spit and the meat rotates in the center. I use kiawe (mesquite) wood or propane just depends what I have on hand. The stands are adjustable from 12” – 24” and I use cinder blocks under the stands.
    Pics 1-4 Pig rod, adjustable stands, and the motor,
    Pics 5&6 the Chicken spit and coupler,
    Pic 7 Motor in the stand
    Pic 8 Spit tips
Name:	Huli Huli Setup 1.jpg
ID:	6913Click image for larger version.
Name:	Huli Huli Setup 2.jpg
ID:	6914Click image for larger version.
Name:	Huli Huli Setup 3.jpg
ID:	6915Click image for larger version.
Name:	Huli Huli Setup 4.jpg
ID:	6916Click image for larger version.
Name:	Huli Huli Setup 5.jpg
ID:	6917Click image for larger version.
Name:	Huli Huli Setup 6.jpg
ID:	6918Click image for larger version.
Name:	Huli Huli Setup 7.jpg
ID:	6919Click image for larger version.
Name:	Huli Huli Setup 8.jpg
    Hopefully I will get to huli huli a pig on July 4th and again on the wife’s birthday (happy wife, happy life!).
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    That's a fine looking rig you've got... I thought Hawaiians cook em in the ground with banana leaves and hot rocks.
    Pic 8 Spit tips
    Oh yeah .... now I'm REALLY getting hungry (in my neck of the woods, it's lunch time now so double threat here) I can see why you mentioned you might want to make the base of the stands wider. Let's us know how they hold up. You can always weld the current stands to a wider plate or weld tabs on the feet of the current base to bolt them onto the cinder blocks(?)
    Nice to see it all together and set up - ready to go!
    You could make an extra set of bases with a spike on the bottom so that you wouldn't need the blocks. Click image for larger version.
    Nice setup! It looks like that will hold a pretty big hog.
    - Dr. AR Dykes
    The Boonies of Texas
    Well living in the middle of thousands of acres of Texas Mesquite I was quite shocked to find it grows in Hawaii. I learn something new every day. Very nice work on the motorized spit.
    Thurmond
    Miller Bobcat 3 Phase,
    EVERLAST PowerUltra 205P
    Ah, but maybe the cinder blocks are also to raise everything up so that larger pieces of meat can be cooked!
    Thurmond kiawe cooking is great, from the meat to how the house smells two days after.
    Zoama/Undercut the cinder blocks are to raise the stands but more importantly the provide a level surface. Once I deciede where the dedicated cooking area will be in the yard I might use a setup like Zoama suggested.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    From the looks of it, you have NO IDEA what you are doing. You need a couple of "inspectors" to check it out for you and to ensure the food is edible ....
    That's the purpose of the holes... pull the pins and raise the upper half to the desired hight.
  1. Project 1 from Winky. Category: metal art
    By Winky in forum Metal Art
    Last Post: 02-12-2013, 12:54 PM
  2. Project 5 from Trip. Category: Metal Art
    By Trip59 in forum Metal Art
    Last Post: 01-12-2013, 03:37 AM
  3. Stainless Fryer Cooker
    Last Post: 08-03-2012, 03:42 AM
  4. Project 2 from NRM Category 4: Portable Stand
    By NRM in forum Other Custom Fabrications
    Last Post: 07-31-2012, 05:05 PM
  5. Project # 8 from Worntorn- another driveway gate setup
    By worntorn in forum Other Custom Fabrications
    Last Post: 06-23-2011, 08:49 PM
