Results 1 to 20 of 40
Thread: Air Dryer?
    As with pretty much any kind of dust, best not to breath in any of the desiccant if there is powder in the canister ....
    That is a great deal from Tooltopia. I'm grabbing one to incorporate into my shop air system. Hopefully I will see some better tool life as well as consumable life on the plasma.
    Everlast Powertig 200DX
    Miller Synchrowave 200
    Hobart Handler 210MVP
    HTP Microcut 30
    Here is a picture of the dryer. Air goes into separator on far right, out of that into a copper tube that wraps around right side tank (which I *think* is just an empty tank), from there it goes into the bottom of the left tank (through the bottom separator), up through the dessicant, out the top and to the plasma. The fitting coming out the top (of the left tank) has a "T", one side goes to the plasma, the other side goes to a check valve, then to the right tank (no outlet, just a 'dead end' into that tank. Not sure of the purpose behind that though.
    Miller 251 MIG
    Racin' Tacoma Build Thread
    I welded up 2 one for my buddy, we installed his but he does not use his compressor that much.
    Mine still needs to be installed but there are many on the web that use them.
    hav fun
    Tom
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    I received the Motorguard filter today. Super quick shipping from Tooltopia. I'm impressed.
    HTP Microcut 30
    hav fun
    Tom
    Printed (37", 2" pipe, 19" high make sure inlet points down) the short version from Franz. If bored this weekend, might build it. Then the installing it part comes in. His explanation of how it works sound solid.
    That is a good idea for sure. I may build one just for the heck of it, I need to put something coming directly off my compressor to keep the moisture out of my air tools.
    Miller 251 MIG
    Quote Originally Posted by Tacoma747 View Post
    I will probably build it and put it after the tank to start (lazy). If I see a lot of water in it. Then I will move it to the tank. Guess I should make two, since I have two units.
    Forgot the pic:
    Miller 251 MIG
ID:	6925 home made filter dryer Click image for larger version.
ID:	6924 cheap 95 percent dessicant.
    Thats a good idea Rod, may have to look into doing something like that in the future, can't ever have TOO dry of air right?
    Miller 251 MIG
    How do you change the desiccant in your home made dryer, Rod?
    has a bung plug on top to fill and a bung plug on bottom to drain litter use a piece of stainless steel welding rod to knock the stuff loose to fall out of bottom plug hole. oh this is not my dryer i am making one but using a different container so easier to change dissnent . was going to use water filter housing since easy to open and dump stuff and refill and there rated a 150 psi http://www.ebay.com/itm/10-whole-Hou...item35a33cdf15
    Couldn't see the plug on the bottom and couldn't imagine you taking it off the wall and shaking it upside down to get everything out! LOL
  1. ??Rod Dryer Idea??
    By smithkf4gyp in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 02-18-2018, 11:55 PM
  2. Air Dryer Recommendation
    Last Post: 08-07-2015, 01:59 PM
  3. argon air dryer
    Last Post: 12-04-2012, 11:37 AM
  4. Argon Dryer
    Last Post: 11-28-2012, 02:07 PM
  5. inline air dryer
    By johnson697 in forum Personal Projects (no welder required)
    Last Post: 11-01-2012, 03:31 AM
