Thanks for the info. I'm off to spend more money. Yay!![]()
They are required...if you want your consumables to last...and your torch to be good.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
with 3 filters that like getting the filter holder for free at the price thanks going to by buy one for a spare .
Thanks for the tooltopia link. I wind up ordering from them at least once a month. S/F.....Ken M
Lincoln Power MIG 300
Everlast 160STH
Miller DEL 200 welder/genset
Miller XMT300
I took a dryer off a dental air compressor I got for free (stripped it down), put a regulator/separator in front of it, then the separator on the plasma itself. I have yet to see even a drop of water in either separator, although I KNOW there is moisture in the lines (can feel it when unhooking the line). The dental dryer is just a big dessicant tank, with copper tubing run around another tank many times, and a sort of 'storage' tank. I should take a picture of it, would not be hard to copy if someone wanted to do so.
Miller 251 MIG
Racin' Tacoma Build Thread
As with pretty much any kind of dust, best not to breath in any of the desiccant if there is powder in the canister ....
That is a great deal from Tooltopia. I'm grabbing one to incorporate into my shop air system. Hopefully I will see some better tool life as well as consumable life on the plasma.
Everlast Powertig 200DX
Miller Synchrowave 200
Hobart Handler 210MVP
HTP Microcut 30
Here is a picture of the dryer. Air goes into separator on far right, out of that into a copper tube that wraps around right side tank (which I *think* is just an empty tank), from there it goes into the bottom of the left tank (through the bottom separator), up through the dessicant, out the top and to the plasma. The fitting coming out the top (of the left tank) has a "T", one side goes to the plasma, the other side goes to a check valve, then to the right tank (no outlet, just a 'dead end' into that tank. Not sure of the purpose behind that though.
Miller 251 MIG
I welded up 2 one for my buddy, we installed his but he does not use his compressor that much.
Mine still needs to be installed but there are many on the web that use them.
hav fun
Tom
Everlast PM256
Millermatic 180
Longevity Force Cut 80I
13" metal lathe
Small Mill
ect, ect.
I received the Motorguard filter today. Super quick shipping from Tooltopia. I'm impressed.
HTP Microcut 30
That is a good idea for sure. I may build one just for the heck of it, I need to put something coming directly off my compressor to keep the moisture out of my air tools.
Miller 251 MIG
Forgot the pic:
Miller 251 MIG
Thats a good idea Rod, may have to look into doing something like that in the future, can't ever have TOO dry of air right?
Miller 251 MIG
has a bung plug on top to fill and a bung plug on bottom to drain litter use a piece of stainless steel welding rod to knock the stuff loose to fall out of bottom plug hole. oh this is not my dryer i am making one but using a different container so easier to change dissnent . was going to use water filter housing since easy to open and dump stuff and refill and there rated a 150 psi http://www.ebay.com/itm/10-whole-Hou...item35a33cdf15
