Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: Air Dryer?
ID:	6925 home made filter dryer Click image for larger version.
ID:	6924 cheap 95 percent dessicant.
    Thats a good idea Rod, may have to look into doing something like that in the future, can't ever have TOO dry of air right?
    Miller 251 MIG
    Racin' Tacoma Build Thread
    How do you change the desiccant in your home made dryer, Rod?
    has a bung plug on top to fill and a bung plug on bottom to drain litter use a piece of stainless steel welding rod to knock the stuff loose to fall out of bottom plug hole. oh this is not my dryer i am making one but using a different container so easier to change dissnent . was going to use water filter housing since easy to open and dump stuff and refill and there rated a 150 psi http://www.ebay.com/itm/10-whole-Hou...item35a33cdf15
    Couldn't see the plug on the bottom and couldn't imagine you taking it off the wall and shaking it upside down to get everything out! LOL
    Here is something to add to your air system to remove water a "Franzinator"
    http://www.shopfloortalk.com/forums/...ead.php?t=8431
    have fun
    Tom
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    I also use the motorgaurd and it is great. Down the road I might make something like Rods setup but only if the motorguard starts to fail and its not the a quick filter change fix.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    have fun
    Tom
    Hey Tom,
    Pretty simple to build. Have you tried one? Do they work well?
    I welded up 2 one for my buddy, we installed his but he does not use his compressor that much.
    Mine still needs to be installed but there are many on the web that use them.
    hav fun
    Tom
    Everlast PM256
    Millermatic 180
    13" metal lathe
    Small Mill
    ect, ect.
    I received the Motorguard filter today. Super quick shipping from Tooltopia. I'm impressed.
    Everlast Powertig 200DX
    Miller Synchrowave 200
    Hobart Handler 210MVP
    HTP Microcut 30
  11. #31
    hav fun
    Tom
    Printed (37", 2" pipe, 19" high make sure inlet points down) the short version from Franz. If bored this weekend, might build it. Then the installing it part comes in. His explanation of how it works sound solid.
  12. #32
    That is a good idea for sure. I may build one just for the heck of it, I need to put something coming directly off my compressor to keep the moisture out of my air tools.
    Miller 251 MIG
  13. #33
    Quote Originally Posted by Tacoma747 View Post
    I will probably build it and put it after the tank to start (lazy). If I see a lot of water in it. Then I will move it to the tank. Guess I should make two, since I have two units.
  14. #34
    The air needs to be hot for it to work properly.
  15. #35
    Oh that's right. Guess I have to do the whole project.
  16. #36
    Something I did at one shop that really helped keep the moisture out of the air was to run the piping up to the ceiling from the compressor. Then I had a drop of pipe almost to the floor, and installed a normal water trap there, then back up to the ceiling to run to the rest of the shop.
  17. #37
    Giant P trap with a water trap in it. If I can get the parts at Home Depot I will make Franzinator, otherwise might try that. Thanks
  18. #38
    That's a good idea. It allows the air to cool as much as possible. Cooler air allows the moisture in the air to condense which then drops to your water tap.
    So along this line of thought, wouldn't the Franzinator work better further away from the compressor where the air is cooler? The air expands in the Franzinator, further cooling it and extracting as much moisture as possible? If the air is hot, the Franzinator will be hotter than it could be and the air might not want to let go of its moisture as easily(?)
  19. #39
    I just love the name franzinator...
    Miller 251 MIG
  20. #40
    It was mostly gravity that was at work here. The moisture would fall out of suspension in the air. The temp of the air was pretty stable by then. It would only cool at the point of expansion which for standard air tools was at the tool valve. Not much if any pressure drop in the lines, so no real cooling taking place.
    I can see how if you had an expansion tank right after the pump and before the tank, you would get a real cooling effect. Also most larger compressors have some kind of heat exchanger in the lines leaving the pump going to the tank. That would help to condense out moisture, too.
  1. ??Rod Dryer Idea??
    By smithkf4gyp in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 02-18-2018, 11:55 PM
  2. Air Dryer Recommendation
    Last Post: 08-07-2015, 01:59 PM
  3. argon air dryer
    Last Post: 12-04-2012, 11:37 AM
  4. Argon Dryer
    Last Post: 11-28-2012, 02:07 PM
  5. inline air dryer
    By johnson697 in forum Personal Projects (no welder required)
    Last Post: 11-01-2012, 03:31 AM
