Results 1 to 3 of 3
Thread: Custom Built Multi Tool, Not Harbor Freight, Not Snap On
    Default Custom Built Multi Tool, Not Harbor Freight, Not Snap On
    Had to set the timing on my old tractor, needless to say the vibration damper had paint and a light film of rust on it so you could not see the timing marks.It was about a 2.5 hour job removing sheet metal and shrouds and the alternator to clean and mark the damper.My hand and arm were not small enough to get there. I had my oldest daughter run the tractor while we made this tool and used it. I took a 3/8" piece of aluminum tubing added a little bend and an SS Brush that cleaned the pulley, a piece of soapstone to fill the timing marks, and a sharpie marker to mark 17 degrees.Saved a lot of time and it worked.They will probably have these at HF this winter.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
    Another Chinese knock-off come winter and you will not get the millions for it.
    Have to see if Mark will count this one for the contest. Looks legit to me, and is that duct tape. How can it not count, SS brush, black sharpie and duct tape. And some soap stone in there too. Talk about your multi tool.
    What will they think of next?
  1. Harbor Freight Welding Cart
    By Depdog in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 02-05-2018, 06:30 PM
  2. modified harbor freight cart
    By dzljon in forum Hobyist Projects
    Last Post: 09-15-2014, 02:16 AM
  3. Upgrading a Harbor Freight 20 Ton Press
    Last Post: 06-11-2011, 04:14 PM
