Results 1 to 16 of 16
Thread: Pt250ex foot perception acting up.
  1. Default Pt250ex foot perception acting up.
    Well my foot parcel is acting up on my 250ex. Some times when I strike an arc (hf start) nothing happens. When it dose strike an arc I have no amp control, some times I don't have full amp control but some, some times when I release the perception it still has a low amp arc.what is going on with my machine? Can this hurt my welder? What can I do to fix this problem? Im in the middle of a project with a tight deadline and this is killing me! Help please
    Sent from my DROIDX using Tapatalk
    It is supposed to say peddle dang auto spell
    Did you take the foot pedal off line and make sure that is the problem?
    Do you have a good ground?
    Check the pedal connector with a DVM. Pins 1-2 should be the switch. Pins 3-4 should be the pot. I recall around 2k Ohm when switch closes and should ramp up to ~50k Ohm fully depressed. Jumper (shorted) for pedal feed back is pins 6-7.
    Double check connections, correct polarity, switch settings, AC Balance if using AC.
    Millermatic 251 with 30A
    Synchrowave 180
    Hobart 100 MIG
    lathe & RF45
    Power TIG 250EX
    Spectrum 625 X-TREME
    Quote Originally Posted by 5440 View Post
    Also 4-5 will be the reverse of 3-4. It is a pot (3 pole) with a common, pin 4.
    Jan 2010
    Chugiak , Alaska
    make sure it's in 2T and not 4T.
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
    It is in 2t. Ito double checked all my settings and connections. Haven't checked it with my meter yet. But im suspect it has metal shavings in it I blew it out with shop air and it worked great for a while than it started acting up again close to the end of the day. So common sense tells me the pot and micro switch should be sealed, are they not?
    never blow clean a switch or electrical.. clean with electrical cleaner if dusty use a vacuum cleaner i have one i have one of these . blowing makes condensation in Electrical stuff and pushes dirt in side switchesClick image for larger version.
ID:	6301Click image for larger version.
ID:	6302 its neat little vacuum i use a lot to clean electrical stuff they are not sealed switch's only marine switches are sealed
    Makes sense....I will try that on Monday. But if it comes down to it im gonna hit up an electronics shop and re build my peddle if worse comes to worse. I sure wish I wasn't having this problem tho, how common is this problem?
    sorta corny lol but i take a big food storage zip lock bag and put the hole pedal assembly inside bag and zip it as far as it will shut really keeps dirt and dust out of the foot peddle . mostly since from all the metal grinding dust in my shop.. I find the really expensive tig foot pedals are sealed to keep dirt out cheaper ones not sealed that crc is great stuff for dirty electrical stuff . lol i like trying new stuff in my food pedal just got Click image for larger version.
Name:	engine rebuild and installs 007.jpg
ID:	6303 new micro switch and a slide potentiometer i ma going to try
    on post 3 CGCINC SAID dose it work ok with out pedal to make sure its the pedal or contacts inside welder not adjusted rite
    Well I would check it with out the peddle but....I let some one use my machine and they failed to use the cooler and melted the lead through the hose. So rather than replace the entire thing I fished the lead through some 3/8 high temp hose (good to 400*) but there wasn't enough room in the torch for the 4t switch that I rarely use so ya, after typing all that I relized I can just jump the pins on the plug
    So I was just thinking if my peddle is dirty....what dose the inside of my machine look like? Do I dare open it to vacuum it out or will that void the warranty?
    lol if some one use my welder and messed it up i would make them pay for what they broke and if not kick there ### till they gave me money , your should just get a new torch if damaged like family guy stewie wears my money man lol
    I got reimbursed for the torch in meterials and more than the torch was worth so im good. It was a quick fix but no 4t switch.
    Quote Originally Posted by srhprerunner View Post
    some times when I release the perception it still has a low amp arc. what is going on with my machine? Can this hurt my welder? What can I do to fix this problem?
    Some or all of your problem might have something to do with your Downslope knob not being set to 0.
    When using the footpedal, if you want the arc to extinguish immediately (as we usually expect it will when using the pedal) Turn the downslope down to 0 seconds. Otherwise, breaking the microswitch (as you lift the footpedal nearly all the way up) will just begin the downslope current tapering, and will not necessary break the arc immediately.
    Maybe your friend who fried your watercooled torch cable fiddled with the downslope knob.
    Too bad you got rid of the torch switch, it would be really handy for a situation like this where your footpedal was acting up. You know you can use the torch switch in 2T mode as well as 4T, in fact I always use 2T mode (I like to set it up so I can vary the switch to throttle the current... seems to work nearly as good as a peddle.)
  1. 250 EX Foot pedal
    Last Post: 09-27-2018, 04:49 PM
  2. Foot Control
    By kepp in forum Everlast Plasma Cutters (PAC)
    Last Post: 08-23-2012, 11:34 PM
  3. pt250ex vs pp256
    By dgarnier in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 10-14-2011, 07:34 PM
  4. PT250EX - only getting HF arc
    Last Post: 10-08-2011, 10:40 AM
  5. Bad foot pedal?
    By sth212 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-21-2011, 08:50 PM
