Results 1 to 7 of 7
Thread: Is there a bit to make a beveled hole?
    Default Is there a bit to make a beveled hole?
    Looking to make a mounting bracket with beveled screw holes, as in this photo.Click image for larger version.
    Is there a specific bit for this? I'm familiar with countersink bits for woodworking, but not aware of the same bit to use on steel. Anybody seen this?
    I use a drill bit that matches the screw head diameter for that. Turns out perfect every time.
    Same here... just don't push hard.
    Here's a countersink for metal.. http://www.thesitebox.com/drill-bits...rsink-bit.aspx
    They do make countersinks for metal. I use them all the time. I usually get them from http://www.mcmaster.com/#countersinks/=h7aw5i.
    I like to set the cordless drill to the slowest gearing, this helps eliminate chatter and prolongs the bits life.
    Power tig 225lx
    Hand tools up the wazoo.
    I don't use a countersink because I like the hole to be the same size as the screw head, flush. Some screw heads taper to a sharp edge and some don't (like decking screws).
    Thanks- good to know there are some options to explore.
  1. Cant make up my mind
    By Steveg63 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-28-2014, 03:55 AM
  2. Replies: 8
    Last Post: 12-05-2012, 06:04 AM
  3. filling a hole
    Last Post: 10-18-2011, 12:18 AM
  4. Anybody make covers to fit?
    By toolman_johnny in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-07-2011, 01:40 PM
  5. How do I make the arc quieter?
    By nanaf in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-05-2010, 01:12 AM
