Results 1 to 20 of 44
Thread: Need some help with wiring my I-MIG 200 pigtails?
    Default Need some help with wiring my I-MIG 200 pigtails?
    Went to the local electric store and had some problems.
    I wanted to wire a 220v plug on the welder cord and then make two pigtails to come off that, one for a nema 6-50 220 outlet, and one for 110v.
    The guy at the electric store said that can't be done. He said I would need to physically change the plug from 220-110 each time I wanted to switch which I know is wrong.
    How have you guys wired your welder to run off 220 and 110. What exact type of male/female plugs because he made it sound like this is impossible.
    Thanks for any help!!
    Found this.... Dave, can you tell me the exact 110v plug you used so I can tell this guy?
    DaveO - I should have responded to these posts sooner- I bought parts for a 110 pigtail and finally had some playtime today. Got the pigtail wired with a 110 plug and a nema 6-50 receptacle, and it runs like a champ! Did some mig and stick, very impressive.
    The I-MIG 200 is an auto voltage sensing unit so you should wire the dual voltage welder directly to a 240V plug and then connect to the 120V branch through a 240V socket/outlet to a 120V plug extension cord/pigtail.
    There are 2 reasons for this.
    First, 120V plugs are typically only rated at 15-20 amps and 240V plugs are typically rated at 30 amps and above. By connecting the dual voltage machine as described above, the 120 plug will never be exposed to a high current overload condition which can cause it to overheat and catch fire.
    Second, the 120V plug is only rated to have 120V across it's contacts. If a higher voltage is applied than what it is rated for, it can/will eventually arc across the contacts and create an a short or partial short overload condition. By connecting the welder/cutter as described above, the 120V plug will not arc between conductors since voltages greater than 120V will never be applied to it.
    EDIT: I used a 250V, 30A, L6 style Twist Lock Plug on the welder and a 250V, 30A, L6 style Twist Lock Receptacle that connected to a 120V, 20A plug for the pigtail.
    http://www.generatorjoe.net/html/web...quailplug.html
    http://electricalsafety.lbl.gov/asse...igurations.pdf
    You want to use a 2 pole 3 wire grounding connection.
    __________________________
    Everlast Power I-MIG 200
    Everlast PowerUltra 205P
    Everlast SM 200-N
    Thermal Dynamics Cutmaster 42
    Quote Originally Posted by kenwhite View Post
    EDIT: I used a 240V, 30A Twist Lock Plug on the welder and a 240V, 30A Twist Lock Receptacle to 120V, 20A plug for the pigtail.
    Wouldn't have a picture of all the plugs would you?
    I really need to show this guy what I need since he said there's NO way to go from 220 to 110
    Happy to help- it's a DIY thing, you do it all with parts from the Home Deep.
    I will eventually get a 50 amp circuit wired into my garage, so I attached a NEMA 6-50 plug to the welder.
    I made an extension cord for the 220v 30a dryer outlet in the house: an appropriate dryer plug, a length of 3-wire (white / black / green) cable (I forget what size, but I can get it for you later if you need it), and a NEMA 6-50 receptacle.
    For the 110v pigtail I bought a 110v 20a plug, a length of 3-wire cable (again I don't remember the wire size), and another NEMA 6-50 receptacle, and wired it all together using the wiring instructions on the plug / receptacle packaging. Fundamentally it all comes down to black, white, and green wires, and making sure the black wire from the wall socket, for instance, connects to a black wire in the cable. As Ken White says, the machine is auto-sensing so nothing complicated is required at your end. I plug into the wall, and connect the 6-50 plug from the machine to the 6-50 receptacle on the pigtail, and that's it.
    Tips and Tricks:
    ~ In case any one else is reading this- DISCARD any plug that arrives with your machine. It is not meant for use in North America. For people outside North America check your local electrical codes to see if the supplied plug is consistent with your local codes.
    ~ I mounted the NEMA 6-50 receptacles in junction boxes- be sure to buy one deep enough that the receptacle has clearance and does not touch any conducting surfaces. This is just a disaster-avoidance tactic.
    ~ The Home Deep may have the equivalent of "drops" at their cable cutting location, odds and ends left from other customers, that are discounted.
    I'll post a photo later if it will help~
    Last edited by DaveO; 04-03-2012 at 03:13 PM. Reason: change to info about supplied plug
    I can snap one when I get home, and post it, if you think it will help.
    Everlast SM 200-N
    The welder has 3 wires, black - hot for 120V or 240V, white - neutral for 120V and hot for 240V and green - ground for 120V or 240V. Like I said, the welder is auto sensing so wire it just like you are wiring it for a 240V circuit and then wire the pigtail to match using the 120V/240V wire ID's above.
    Everlast SM 200-N
    Don't bother... I think I've got enough info now! Thanks though
    Just my 2 cents...
    Are you using a 3 wire plug/cord or 4 wire from your 220 outlet???? I will break it down.
    If it is a 4 wire you are good to go... 2 wires are hot (if wired correctly) it should be the red and the black. Then the white is the neutral and the green is the ground. For a 220 3 wire outlet you use both hots and a ground wire. For a 110 volt outlet you would use one hot (it does not matter red or black) then the white/neutral and a green/ground. Like mentioned above a fuse to protect the 20 amp outlet would be recommended.
    On the other hand if it is 3 wire plug and cable, 2 wires are hot probably the black and white. Then the green is the ground and no neutral. For 220 you have 2 hots and a ground. Now for 110 your do not have a neutral. So that is maybe why the electrician said you cannot do it. The ground and the neutral are somewhat the same. BUT if you use the ground as a neutral and the ground wire is damaged somewhere near the breaker box ALL the appliances that have the ground hooked to the metal case will become LIVE. That is why is is not legal (code) to use the ground as a neutral return.
    I hope this helps you out. It sure would be a nice idea to have a 110 and 220 on the end of a cord. But without a 4 wire cord, it is not safe... Especially if you are working outside or in a damp area like a garage. BTW if you do it, a 110 volt 20 amp gfci would be highly recommended.
    That is why all new houses (last 10 years or so) are wired wired with a 4 wire plug for the stove and maybe dryer. So they are not using the ground as a neutral....
    Hope that made it as clear as mud....
    Shade tree MIG welder.
    Now a Shade tree TIG welder.
    I recall having a tough time visualizing this when I first got the welder, and thinking the wiring was going to be some kind of multiple cross-connecting deal. I couldn't visualize it at all. Part of the misapprehension may be the term "pig tail", which put the multiple cross-connect scenario in my mind. If you substitute the word "jumper" it may be easier.
    When I want to use 220v (because I don't yet have a 220v 50a circuit) I plug the machine into the jumper I made for the dryer plug. Machine plug connects to the 6-50 receptacle, which connects to the dryer oulet.
    When I want to use 110v I connect the machine plug to the 6-50 receptacle on the 110v jumper, and plug the other end into the wall. Everything is in-line, with nothing hanging loose or unused, as the term "pig tail" may lead you to believe.
    When I want to use 220v (because I don't yet have a 220v 50a circuit) I plug the machine into the jumper I made for the dryer plug. Machine plug connects to the 6-50 receptacle, which connects to the dryer circuit.
    I think the word jumper might help me explain.
    Thanks for all the help everyone, I've got all this info compiled on a small piece of paper with numbers and plug/outlet pics..... Heading back to the store so we'll see how this goes.
    I have a Nema 6-50 in my shop but I like the idea of the twist lock on the end of the welder so if I am using 110v with a long extension or whatever, it won't just "pull" out.
    So let me see if I can visualize YOUR situation:
    For the 220 jumper, you need a 6-50 plug for the wall, a length of cable, and twist-lock receptacle, and a twist-lock plug for the machine.
    For the 110 jumper, you need a plug for the wall, a length of cable, and a twist-lock receptacle.
    Did I get it right?
    A couple thoughts:
    ~ Keep in mind there will be a voltage drop over long cable runs. On 110v the machine's duty cycle decreases (by how much or to what, I don't know) but a long extension cord may pose a problem.
    ~ Many generators use twist-lock receptacles, so a matching twist-lock plug may expand your useability.
    Did I get it right?
    A couple thoughts:
    That's exactly what I have in mind and on the paper.
    I will be buying a generator later on, this guy
    And it does have the twist lock on it
    OK, I got everything except the female twist lock....it will be here tomorrow.
    Thanks for gettin me straight!
    "The difference between stupidity and genius is that genius hasit's limits".... Albert E.
    CG,
    NO !!!!!
    You will be in serious danger of electrocuting yourself !!!
    When you plug in one of your cords, you have live male pins on the other end.
    STOP !!!
    rivets
    Okay, now that I've calmed down, here's what you need to do.
    You need the male plug on the welder and a mating female receptacle on each of your cords.
    In fact, if your welder cord is long enough to reach its dedicated 50 amp outlet, you only need the one cord for 120 volt operation.
    rivets
    why not just buy the miller input cable and plug kit only like a 100 bucks then is safe and looks nice , here is were you can buy cords and plugs http://www.brwelder.com/indextemplat...&SubCategory=8 those MOTOR GUARD FILTER # M-26 are nice i use one for dry clean air for my plasma cutter
  19. Default
    I agree with Rivets having a plug to plug could hurt someone. I think you need a 6-50 Plug on the welder, a 6-50 Receptacle to 5-15 Plug for the pig tail to a 120v outlet and a 6-50 Receptacle to twist lock plug for the generator. Just my $.02.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    lol... I told you guys I don't do wiring correctly!!! lol
    Ok... So I'll just change it around a little and I'll be good. Thanks Dave O, and thanks everyone else for not wanting me to die!!!
  1. 210 ext wiring
    By GaveUpOnTV in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-30-2016, 03:59 AM
  2. Generator Wiring
    By SeanMurphy265 in forum General Welder Questions
    Last Post: 05-26-2011, 01:09 PM
  3. Wiring up my 250ex
    By PinkNinja in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-01-2011, 02:23 PM
  4. wiring and breakers
    By yotarover in forum General Welder Questions
    Last Post: 07-08-2010, 08:03 PM
  5. Wiring
    By herb in forum Everlast Plasma Cutters (PAC)
    Last Post: 03-02-2010, 07:49 PM
