Results 1 to 3 of 3
Thread: What is 95/5 Argon/Oxygen gas used for???
    Default What is 95/5 Argon/Oxygen gas used for???
    I ran across someone selling a cylinder of 95/5 gas. I thought you need to keep oxygen away from your welds???
    Shade tree MIG welder.
    Now a Shade tree TIG welder.
    I can answer that!!
    I just asked a similar question. Mig welders use mixed gas when welding.
    Oxygen is normally added to argon in amounts of 1%, 2%, or 5%. When oxygen is added to argon, it improves the penetration pattern. It also improves the bead contour and eliminates the undercut at the edge of the weld. You use argon-oxygen mixtures in welding alloy steels, carbon steels, and stainless steel
    There are many different combinations and they are all used for welding different materials.
    http://www.everlastgenerators.com/fo...al-world-input
    Oxygen additions can also be added in to make the gas active and actualy strengthen the weld due to intentional oxide formation.
  1. 100 PSI argon flo?????
    Last Post: 06-09-2016, 08:51 PM
  2. Why 100% Argon or Argon/CO2 75/25%
    By mdennis in forum General Welding Questions
    Last Post: 08-09-2013, 04:11 AM
  3. Air/Argon
    By ChadP in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 02-09-2013, 09:20 PM
  4. propane acetylene oxygen
    By Rodsmachineshop in forum General Welding Questions
    Last Post: 05-23-2012, 03:46 PM
  5. ARGON and ARGON/CO2 TANK SIZES
    Last Post: 10-13-2011, 05:19 AM
