The design calls for casters at the front and rear. So I just flipped the angle to create that nice overhang for mounting purposes. Its a real easy clamping situation. One on each side! After the pieces were matched up, I scribed chalk lines to indicate where I am welding and what part should be ground down to remove the paint and rust. Like I said before, I didn't want to strip the whole frame of the primer. I like to use that hammered finish from Rust.O.Leum. It can take some minor rust and surface imperfections nicely
