Results 1 to 2 of 2
Thread: Set up questions on pp80
  1. Default Set up questions on pp80
    Hello to all. I am trying to set up my new pp80, and am not at all liking the plastic airline set up with the machine. It may have been on another site, but i read some posts on replacing the line with something using more typical connectors than the push ons. The filter end is easy...1/4 npt, but the machine end has me scratching my head. The push in fitting does not seem to come out. the outside threads have me stumped as to what size they are. looks too little for 1/2, too big to be 3/8 npt. any suggestions appreciated.
    Bigjoe,
    I am not sure what part you are looking for. The push in connectors are very good overall, much better than the former hose barb connectors. No the push in fitting should not come out. They are metric threaded. Do not change them out, or you will affect your warranty on that portion of your unit, since they screw into the solenoid. The plastic air line is far superior to the old style, and much more responsive. If the line is inserted properly, it shouldn't give any problems. You may need to make sure the plastic line is cut square before you push them in, but other than that it should work.
  1. Questions About I-Mig 140
    By esg612 in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 02-22-2017, 07:26 PM
  2. PowerTig 185 questions
    Last Post: 04-19-2013, 08:19 AM
  3. New 200DX questions
    By Bigwilly01 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-19-2012, 03:35 AM
  4. 256 questions
    By tnc110 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-02-2012, 02:03 PM
  5. Pu 205 questions please
    By Dne007 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-13-2012, 09:12 PM
