Results 1 to 20 of 29
Thread: The UPDATED line of welders and then some...
    Default The UPDATED line of welders and then some...
    Well,
    Its been a long time coming for some of you. You've wanted to see them. You wanted to know what they look like. So, here they are...Paint still cooling.
    This isn't the complete line as we are adding products to our Power I-MIG and adding 2 dedicated stick welders to the product line up.
    But you can get the idea. We have tried to unify our product line in layout and function so that less confusion over operation will exist...though there may be some still...there always is. We will try to make the wait and anguish time as short as possible. We estimate 2weeks before they ship from CA. Possibly 3...just trying to be on the safe side.
    It has taken a bit longer to make some changes, thanks to a two week chinese holiday, a couple of our own and some serious hard work to get it right. But we feel it is better to wait a little longer to get things right. We have added a few features such as a lift arc on the 250 EX, and a post flow timer on the Power plasmas which will allow you to adjust post-flow cooling to increase consumable and torch life, and a couple of other features that will improve overall function of the welders.
    We, of course, will be continuing to improve our welder line and fine tune our products to meet and surpass our customers expectations.
    We will soon have another major announcement/introduction as far as our welder line goes though it is a little ways out and about to enter the testing phase. So stay tuned.....
ID:	114   Click image for larger version.
ID:	115   Click image for larger version.
ID:	116   Click image for larger version.
ID:	117   Click image for larger version.
    Here are a couple more.
ID:	119   Click image for larger version.
    Looks good. Are the knobs different colors to signify what their usage is for, ie. green for AC, blue for plasma, yellow for DC, etc.? Not like I know what the colors are assigned to but just asking.
    The color grouping is for easy identification. We have added a couple of non cosmetic changes as well...Which is why we have gotten a little more delayed than we were planning originally. The 250 EX has a lift arc start added for the Tig...
    Green are generally adjustments related to the panel control of the weld cycle.
    Red are amperage related.
    Yellow are AC.
    Blue are pulse.
    Black switches are function selectors.
    These are standard colors we have picked in our fist generation to represent our functions and should make it easy for the new welder to "learn" the product.
    I know the green arc force control is not amperage coded, but it should be for final delivered product. These are the first "proofs" that we received before final assembly. So, we have taken a couple more steps in making the arrangement of the knobs and features more finely tuned.
    Wow, quite a styling change.
    I like the addition of "lift-start" TIG on the 250EX.
    I'm saving my pennies.
    Regards,
    John
    whats the benefit of having 'lift start' vs. high freq. start?
    The lift start will eliminate interferance problems associated with HF starts. It is generally used for steel and all DC purposes. But it is not used on AC because of contamination of the tungsten that is involved with aluminum.
    To lift start, you simply place the electrode on the metal and gently lift up with "power" on pedal to ignite arc.
    It also makes tig welding more friendly to pacemaker patients or people with computers, or sensitive electronic equipment nearby.
    I have one on order now and can't wait to get it!
    Wayne
    Wayne,
    Which one do you have on order?
    Default Any update on shipment??
    HI
    Any update on when the new units will be in? Looking for a Power Master 256on my door step soon!!
    Have fun
    Acourtjester
    Mark,
    I have the 250EX on order.
    Wayne
    I keep hearing that 2 weeks sounds about right. But that started two weeks ago.
    Seriously, they should be here sometime around the 30 of oct-1st of november
    We have a couple of last minute updates on a unit or two that has held up the entire shipment. But, we want to make sure they are done as specified. Nothing major, mostly convenience items...but unfortunately when you ship in container quantities, a small improvement can hold the whole shipment up.
    Thanks for the update. Sounds like you could apply Lean Manufacturing to your manufacturing cycle.
    Wayne
    Guys,
    The challenge of the process of bringing updates and improved ideas, and specification changes is a great one. We can make specificaitons, but at times, we are at the factories mercy for scheduling. We communicate daily, but we are on a 12 hour time difference. So, communication is often delayed. Even night time emails, im's, pm's, and phone conferences are not enough to get things done on OUR time schedule. The factory is extremely reliable, and a high quality factory,but Chinese culture, language differences (Usually their English is fairly decent, but it is often the Kings English if you know what I mean) comes to play in our process. Also, a new factory is to be completed by the first of the year, so it has slowed down current manufacturing to be ready for transition to the new facility.
    Well, its time to piddle out a couple more photos.
    THIS is our new line of stick welders. These have the works as far as adaptive arc force control technology/hot start etc, and even have a special port to burn those dreaded 6010's. We can also offer special add on Tig packages as a simple scratch start tig for DC.
ID:	136   Click image for larger version.
    did everlast update the migs? if so do you have any pics of them?
    We have updated and brought out different amperages. We have a panel front similar to others, but the look of them remains similar except the panel front. Our 250 amp unit is much different. It is a roll around unit with spot and stitch timer control.
    Here is an unfiinished 200 panel still on the production line.
    Mark,
    I ordered a 250EX
    Wayne
  19. Default
    Any chance of getting the dimensions of the "new" Powermaster 205? I had ordered one back in February and built a cart to hold it and my MIG25OD and by looking at the pics of the new model may have just wasted a lot of time lol.
    If I could get those dimensions I might be able to modify it to make it all work.
    I will get you the exact dimensions soon. Tommorow. maybe...lol...Yes, I will get you specs. I just picked up the "air shipment" of advance units for an event to be announced next week. The others are in transit, but I will work on getting dimensions Sunday afternoon.
    Stay tuned, we might have a suprise or two yet to post. We can't let our lurking competition know too much too soon. But indeed, there are things on the way, not talked about and not posted yet..intentionally. It seems our competition has a knack for showing up with a knockoff of our products about 3 months after we debut or even discuss it publicly, and then claim them as their own, even our manuals they have copied, cut and pasted word for word. We are learning not to give away all our secrets until we are good and ready. Don't believe me? Watch wait, and learn.
  1. Updated PowerPlasma 100
    By performance in forum Everlast Plasma Cutters (PAC)
    Last Post: 02-23-2014, 11:15 PM
  2. Replies: 4
    Last Post: 05-23-2012, 06:43 AM
  3. Updated Manuals
    By rengaw21001 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-03-2011, 10:33 PM
  4. 225LX, New, Updated or redesigned?
    Last Post: 12-28-2010, 01:47 PM
  5. Expected Line of Everlast Stick Welders
    By performance in forum Stick Welding (SMAW)
    Last Post: 08-11-2009, 09:38 AM
