Results 1 to 12 of 12
Thread: Power I-IMIG 250P questions
  1. Default Power I-IMIG 250P questions
    Can someone show me some welds done with thePower I-IMIG 250P please.
    Additionally, I would appreciate any input on the machine itself.
    How readily available are the consumables?
    Can you change the torch?
    All input is greatly appreciated.
    Mike.
    Miller 135 Mig
    Miller 211 Mig (Broken)
    Lincoln SP-180T MIG (Wont hold gas)
    HTP MicroCut 875S Plasma Cutter
    HTP Invertig 201 TIG Welder
    JET 7"x12" Horizontal/Vertical Bandsaw
    G0704 Mill "BF20" (Working on CNC Conversion)
    Hypertherm Powermax 1000G3 w/ Machine Torch, 6'x10' CNC Water Table
    Custom Built 5'x5' CNC Router Table w/ Milwaukee 3-1/2 HP Production Router
    South Bend 9" Bench Top Lathe Model C
    South Bend 14"x40" Engine Lathe
    South Bend 9"x32" Vertical Mill
    JD2 Model 32 Bender with Dies
    The torch is either Binzel or Trafimet. These are name brand, and depending upon your local supplier can be bought locally, (and online quite easily). These are some of the nicest and most comfortable torches on the market. We use the Euro quick connect on our units. This is a universal style that every torch manufacturer I believe can make their torches in. This is the same as ESAB and others. One of our guys went and bought a profax with tweco fittings because he wanted a longer torch.
    Thank you.
    Do you know where I could see some welds made with the machine or some pictures?
    Again, Appreciated.
    Mike
    Miller 135 Mig
    Didn't you say you are from S. Florida? Mike in tech support lives in S. FL. He has one.
    Yes, I am in "The Redlands" Just outside of Miami.. Above/West of Homestead.. Everglades in my back yard.
    I'm currently working at the Miami Art Museum so, I drive a little north everyday.
    Just on the edge of Biscayne Bay/Miami Beach.
    Miller 135 Mig
    This is with my Imig 200 12gauge sheet, the 205p is more machine with more features.
    Here's some I have done with a 160/200 series unit. This is 1/4" steel to 3/16" wall tubing if I remember right, with .030 wire.
    Thanks guys.
    Nice welds.
    Both of you guys are using smaller machines I see. With very good results.
    I am curious about the benefits I will see with the additional features of the 250?
    Mike
    Miller 135 Mig
    Quote Originally Posted by Diabolical View Post
    Thanks guys.
    Nice welds.
    Mike
    No doubt the 250p is a better machine. If I ever get a shop to work in I will get a 250p or the MTS 400. Get the machine you need to do the jobs you do! I'm good with my Imig200, but I have a power arc 200 to back me up when I need it!
    How does the pulse work on thin metals. Particularly stainless and aluminum. I was wondering if you set the pulse slow won't the wire stub in the puddle durring the low amp part of the pulse?
    Everlast PowerTig 250EX
    Everlast PowerCool 300
    Everlast PowerPlasma 70
    Lincoln Powermig 215
    Magnum SG Spool Gun
    Don't jump on my Gomba
    Word to the wise, Mike. When buying tools, buy the biggest and strongest that you can justify ever using. As you move up you get more duty cycle, more power, more features, etc. You never know when you need it.
    How much would you have to pay an hour to get a part welded that you couldn't handle with a smaller machine ? And remember, welding shops don't just charge for the welding. They charge to set up, going to the bathroom, having coffee, preping the work, do the welding, inspecting it, clean up, billing, shipping, etc.
    If you think a welder is expensive, trying hiring a welding shop to do it for you. Then you find out what it really costs to not have a welder. And machine tools for that matter.
    Caveat. I have no affiliation with Evergreen other than I bought 2 machines from them.
    Quote Originally Posted by someguy View Post
    Is Evergreen a division of Conifer welders ?
  1. Power Ultra 250P Tig problem
    By kencal51 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-13-2015, 09:15 PM
  2. Power I-MIG 250p
    By Yofish in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 02-25-2015, 04:25 AM
  3. The new IMIG is here! and I've got some questions.
    By redbeard in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 06-12-2013, 02:24 AM
  4. Questions about the TIG Pulse Option on the Power Ultra 250p
    By Haku in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 06-08-2011, 03:54 PM
  5. power IMIG 205
    By Wrenchtamer in forum Customer Testimonials
    Last Post: 03-04-2011, 12:47 AM
