Thread: CGCINC Project#8: Portable Band Saw Stand
    Default CGCINC Project#8: Portable Band Saw Stand
    I always need a vertical band saw it seems and I liked Powertigs stand he did here... http://www.everlastgenerators.com/fo...Band-Saw-Stand
    I wanted mine to be floor standing.
    The piece of angled metal that mounts to the back of the saw is from a leg raise workout bench that was spare parts. The 1/2" plate base was given to me and the 2 x 4 riser is left over from my Bicep machine build.
    I went to Harbor Freight and bought a $79 portaband for this project.
    The handle sits down in the channel on top of the stand. I used one bolt through the handle to hold it in place.
    I removed the second handle and that is where I mounted the angled piece in back.
    This was a fast and easy stand taking about an hour to complete. It has 3 bolts that I can remove if I need to use the saw manually.
    Nothing fancy, just thought I would share....
    This plate was given to me and it had 1" holes in each corner.
    I cut 1" tubing in 1" sections to slide down in and weld for feet.
    Time to get out the 1/8" filler rod!
    Dec 2011
    RUSSIA.Sankt Peterburg
    CGCINC as always has executed all in the best possible way
    Ruslan
    EVERLAST Power Tig 255 EXT
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    SELCO Genesis 352 pme
    Looks good now wide a piece can you cut with it? I converted th HF saw to strictly vertical but only cuts about 3". Click image for larger version.
Name:	Bills pics 025.jpg
    Bill
    Good job! I like that a lot, might have to steal that idea. You might want to replace the stage to accommodate larger pieces.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    that looks nice, what kind of saw is that? Do you have plans to bolt it down at some point?
    The saw is made by Chicago Electric. I don't plan on bolting it down. The base is pretty heavy and it doesn't move when I use it.
    Eventually I plan on getting a Real vertical saw so this is temporary
  1. Project #3 Milwalkee Band Saw Stand
    By Powertig in forum Hobyist Projects
    Last Post: 12-30-2013, 06:55 PM
  2. (Another) Band Saw Stand
    By its_34 in forum Other Custom Fabrications
    Last Post: 08-17-2013, 02:27 AM
  4. Project 2 from NRM Category 4: Portable Stand
    By NRM in forum Other Custom Fabrications
    Last Post: 07-31-2012, 05:05 PM
  5. CGCINC Project#5: Weight Stand
    Last Post: 12-17-2011, 06:45 PM
