Where you sweaty? If you touch the workpiece and there is a path to ground through you, you will get a tingle. Happened to me yesterday restoring a 1978 Corvette seat frame.
What is the model number of the torch? It will either be a sticker or on the neck of the torch.
I wasnt sweaty...was wearing a sweatshirt and got the tingle through my sleaves where my arm was touching the work piece.
Not sure on the torch model, will check later today. Would the wrong torch prevent it from arcing unless it is near the work piece?
