Thread: Project# 1 Weld Table
    Jun 2011
    Charleston, South Carolina
    Default Project# 1 Weld Table
    Well with my replacement 225LX running flawless I have nothing left to complain about. So it was time to build a weld table.
    Seems that most everyone here has built a monster weld table in their
    6 car garage. I have a 2 car garage and have to utilize every square inch of floor space.
    So this is what I did. I have 2 roll out cabinets under my work bench that I use as
    "saw horses". I removed the wood top off of one cabinet and replaced with 1/4 thick
    stainless plate (this took forever without a plasma cutter).
ID:	4650 Click image for larger version.
ID:	4651 Click image for larger version.
    The top has 42 tapped holes (1/4-20) equally spaced. I have 1/4-20 set screws in the holes so they
    don't fill up with crap.
ID:	4653 Click image for larger version.
ID:	4654 Click image for larger version.
    With the tapped holes I'm going to use hold down (strap) clamps instead of tacking to
    the table.
    Also I made a plate on the side with a removable toggle clamp so I'm able to
    clamp something vertical or horizontal.
ID:	4657 Click image for larger version.
ID:	4658 Click image for larger version.
    The cabinet top is 2 foot square by 30" high. When I'm done welding I can roll the
    cabinet back under the work bench out of the way. So technically I didn't add anything
    new to garage and have the same amount of floor space.
    Next is a weld cart!
    Brian Scott
    225LX
    Speedglass 9002v helmet
    19" Shop Fox band saw
    Ingersoll Rand air compressor
    Dec 2011
    RUSSIA.Sankt Peterburg
    Excellent table (very ergonomic),
    We wait a welding cart
    Ruslan
    EVERLAST Power Tig 255 EXT
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    SELCO Genesis 352 pme
    Very compact and will get the job done. What did the plate cost you. You drilled and tapped it? That took a little time I am sure.
    Nice table! really like the tap hole idea!
    Gil
    powerpro 256
    lincoln 185
    Well done what a great use of space, which looks like it is important. The side plate for the screw clamp is brilliant, turns it into a three denominational fixture. You give me a great Idea....Thanks for sharing.
    Miller Challenger 172 Mig
    Wade Mortenson
    Jun 2011
    The plate was used but only cost $100.
    It didn't take that long to drill, but it took awhile
    to tap them and I didnt break a tap. That's
    one for the record books.
    The plate was 30" X 30" and I cut it with
    a right angle grinder (now I see the purpose
    of a plasma cutter)
    Brian Scott
    225LX
  1. Project #2: small end table
    By johnnymg in forum Personal Projects (no welder required)
    Last Post: 08-12-2013, 04:58 PM
  2. Project #2 from charger 891 hd welding table
    Last Post: 03-04-2012, 12:44 PM
  3. Project #2 Portable welding table
    Last Post: 01-16-2012, 04:18 PM
  4. DVA Project #2: Welding Table
    Last Post: 12-07-2011, 11:06 PM
  5. Project # 2 Welding table
    Last Post: 06-03-2011, 03:47 AM
