doesnt the top have to angle up or else you would be mounting it horizontally flat, and the top frame tube coming back from the neck to the seat post is probably not flat. I am used to seeing something like this:
most of the tank should sit lower than the filler neck.
Millermatic 211 Mig
Lincoln Weld-Pak 100
Century Stick welder
Jet band saw
