Results 1 to 10 of 10
Thread: Source for gas quick connect fitting?
    Default Source for gas quick connect fitting?
    I was just told by arc-zone that EL uses a water q/c for the argon connection at the machine. Anybody know where I can find them? edit: welding direct.com
    Everlast PowerPlasma70
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    Everlast also sells parts, just give them a call.
    I try not to be a pest over there.. ;D
    Had an interesting web transaction ordering those three dollar male connector ends from welding direct... couldn't figure out why the order wouldn't go thru. Then I saw something to the effect of 'spend more $ cheapskate' on the top of the page. So I hit the 'continue shopping' button (five more times). Guess it's a $50. minimum. I got some gloves and other small stuff, a little gas flow checker, it was like a game, "are they going to accept my money this time??" Prices seemed good. Can't blame anyone for defining the kind of business they want to do, but the whole time I was wondering just how high the minimum was going to be.
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    Thats whack. i wouldnt do business with them. why should i keep adding junk i dont really need just to make a small purchase. if they stated the minimum order at the beginning, that is OK, but to make you incrementally add stuff until the order is accepted, thats BS. At least in an ebay auction, you know ahead of time if there is some predetermined reserve price that you have to try to hit.
    Millermatic 211 Mig
    Lincoln Weld-Pak 100
    Century Stick welder
    Jet band saw
    They are in business to hear from pests like you with money in your pocket.
    Millermatic 211 Mig
    Jet band saw
    Quote Originally Posted by Joe from NY View Post
    They ought to carry these:
    They have to be a drastic improvement over the originals with the release lever reversed, and lock-nut. Stronghand Tools. Can't wait to use'em..
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    Are you talking about a quick disconnect for your gas line to disconnect the bottle?
    I use regular air-hose disconnects on my everlast. Since i have one of the multi-process Tig-welder/Plasma Cutter models, i have to switch my gas line from argon to compressed air when i change tools. I got some good hose and spliced in the regular air-line disconnects that you can get from the hardware store. I put them in between the regulator and the welder. They work great and don't leak at all, even 5 years later.
    Spike Customs, Inc.
    Fresno, CA 93727
    ph- 559-549-RIDE(7433)
    -Follow me on twitter!-
    OHH- Yeahh. They do sell them. With a little "Inconvenience":
    I needed one of these Quick couplings - and one of the 7-pin connectors, in order to adapt an existing WP-17 torch to the PP256.
    All in all- I was quoted something like $ 25.- on the phone, plus more than $10.- in shipping. For trivial hardware weighing below 60 grams. NO THANKS.
    That is obscene. IMHO.
    I have standard compressed air fittings on all my machines. i have never had an issue with contamination or leaks. Its so much quicker than unscrewing the compression fittings on the back of my welders.
    Everlast lx225
    Hobart Stickmate LX
    Thermal Arc 400GMS
    10"-22" Grizzly lathe
    Same here... no moisture, no leaks, no money wasted on valves and no problems.
  1. Replies: 0
    Last Post: 07-30-2015, 09:57 PM
  2. Quick connect gas fitting?
    By Dsl power in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-18-2014, 08:52 PM
  3. Argon quick connect for everlast welders...
    By sw2x in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 03-30-2013, 10:10 PM
  4. quick disconnect male fitting
    By tictac in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-04-2013, 04:19 AM
  5. Quick connect gas fitting
    Last Post: 11-09-2011, 04:49 AM
