My apologies.
I have a PowerTIG 200DX.
I plug the pedal in on 2T, and the pedal AMP control (Which is what you use since the panel is disabled) only has a "range" based on the digital display of 3-25 amps.
This isn't correct, but when I Turn the Pedal amp control all the way up it will rip.
When I back it down a few notches it loses all its luster.
It seems the Pedal Amp control isn't linear and I can't set the working amp via the Panel.
How do I know the exact amps I need if it doesn't display?
Spec-C Tuning and Fabrication
