Results 1 to 12 of 12
Thread: PROJECT 1 from JERKY: tig cooler
    Default PROJECT 1 from JERKY: tig cooler
    first thing ill be using computer fans to cool my core. ive already got the power source, just pondering on what fans to buy. im looking for a core now, little tricky to find a copper core one. ill make a reservoir out of some stainless. then to find a decent pump. so running costs:
    power source: FREE, traded for my garage door opener (no longer needed it)
    fans: 3 120mm computer fans... http://www.memoryexpress.com/Products/MX8708 total was $28 (with shipping)
    tubing: ---
    core: https://www.jab-tech.com/Black-Ice-G...e-pr-3422.html $83 (with shipping)
    stainless sheet metal: picked up some scraps for 40$, wont use all of it. so say 20$
    pump: ---
    TOTAL:--
    PICS TO COME ONCE I ACTUALLY START BUILDING IT
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    http://www.jab-tech.com/XSPC-c-326.html they use 1/4 bspp fittings which are just like 1/4" npt without the taper and seal with an o-ring. The fittings are available in lots of configurations like 1/4" through 1/2" hose barb, 1/4 through 1/2" compression or even dry break. All copper or brass.
    nice, i was looking for a site like that! man ferrari red rad... must have! thanks
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    There are lots... here's a couple more http://www.performance-pcs.com/catal...c31b1d9dd81f32 http://www.sidewindercomputers.com/
    So finally got the plasma and tig working. Still have to tweak some things. So im building the resivour out of 16 gauge ss. I plasma out 4.5" x 9.5" sheets. The sheet was only 9.5" wide so thats why i went that way. So here are some pics. It looks really bad, no prep and not correct fitup, but after waiting months for the tig, all i wanted to do was play.... The last pic is a great example of why back purging is required... Lol.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    Not sure what I'm looking at in the last pic..smoke?.. I can't tell if it's gaps or black spots... what did all that and how will you fix it ?
    That ia the inside joint. The white stuff was like fluff and under it was black carbide precipation and sugering. Basically all the bad stuff when welding ss.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    Just in case you decide to take the easy way out http://www.ebay.com/itm/Gman-4qt-Pla...item484269a0fa Name:  whistling[1].gif
    Here's a video with some handy tips for that type of work.
    Nice project! what pump are you going to use?
    Im not sure yet, i found a pony pump for 85$, might just go that way
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    so the rad came in yesturday, and the fans came in tonight and i just had to play... if your wondering why i have 2 clear and one black, its because they were all on sale, but there was a limit of only 2. and i wasent about to pay 18$ for a fan just so they could match.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
  1. School project from Jerky (3g tig root)
    By jerky in forum Hobyist Projects
    Last Post: 02-20-2012, 05:23 PM
  2. My DIY Cooler Project
    By RP62 in forum Other Custom Fabrications
    Last Post: 02-12-2012, 12:02 AM
  3. PROJECT 4 from Jerky: mini bike fenders
    By jerky in forum Other Custom Fabrications
    Last Post: 01-30-2012, 06:47 PM
  4. PROJECT 3 from Jerky: coffin gas tank
    Last Post: 01-30-2012, 06:41 PM
  5. PROJECT 2 from Jerky: welding cart
    Last Post: 01-22-2012, 02:49 AM
