Results 1 to 5 of 5
Thread: Project #2 Cub Cadet dump truck
    Default Project #2 Cub Cadet dump truck
    This 105 cub cadet is about to get transformed into a dump truck. I started out by stripping it down to the frame so that I could split it and add 3 feet in the middle. The section that was added was made from a piece of 1/8" by 6" by 3 feet long. I took it down to a friend of mine that has a break press. More to come.
ID:	4178   Click image for larger version.
ID:	4179   Click image for larger version.
Name:	will cub before.jpg
ID:	4180   Click image for larger version.
ID:	4181   Click image for larger version.
    Miller Syncrowave 250 DX
    Everlast 140st
    Torchmate CNC Plasma Table
    Leblond 19 x 54 Lathe
    Hobart Handler 210 and spool gun
    Lincoln SP250 and spool gun
    Index Milling Machine
    Hypertherm 1000
    9 x 20 lathe
    enco 7 x 12 bandsaw
    Victor machine torch
    Ok, so the next step was to add in the new frame rails.Then we moved on to the drive shaft. It had to be lengthened 3 feet as well. I used a piece of 3/4" cr and turned the ends down to 5/8" to fit the original parts. I also had to add a carrier bearing in the middle to help support the extra length. More to come.
ID:	4183   Click image for larger version.
Name:	will cub drive shaft5.jpg
ID:	4184   Click image for larger version.
Name:	will cub drive shaft4.jpg
ID:	4185   Click image for larger version.
Name:	will cub drive shaft3.jpg
    Everlast 140st
    Hypertherm 1000
    9 x 20 lathe
    enco 7 x 12 bandsaw
    I get the feeling you like cub cadets. Are you going to fishplate the rails? I like the whole idea of building a little dump truck. How many cadets do you have? Looks kinda like your building a small custom fleet. Pretty cool! Gotta love little tractors.
    Cub cadets are nice. I have quite the pile of lawn mowers we use to go mudding with and creakin. Its quite fun. I had a 63 cub cadet a while back. It was the 3rd year of the first motel they made. Traded it and a 70 something for a couple other newer working ones. At my grandmas we got a 62 stored away which was the second year cub cadets made these.
    Gabe
    everlast power arc 200
    lawn mowers
    Yes I love messing with cub cadets. I have 8 cubs total. Yes I did end up fishplating the frame.
    Everlast 140st
    Hypertherm 1000
    9 x 20 lathe
    enco 7 x 12 bandsaw
  1. Mack Dump Truck and Lear Jet
    By cbmkr in forum On Road Fabrication
    Last Post: 07-28-2012, 10:17 PM
  2. Projest #1 Cub cadet Backhoe loader
    By atatro in forum Hobyist Projects
    Last Post: 12-18-2011, 06:38 PM
  3. Project 3 from I_Love_Plasma ~ Parts/Firewood Dump Box
    By I_Love_Plasma in forum Heavy Equipment and Commercial Projects
    Last Post: 10-04-2011, 06:22 PM
  4. Project 1 from Worntorn- Pickup truck bed extender
    By worntorn in forum Other Custom Fabrications
    Last Post: 06-10-2011, 03:12 PM
  5. Little metal truck project
    By SWells in forum Other Custom Fabrications
    Last Post: 03-30-2011, 01:25 PM
