Thread: Cutting grader blades
  1. Default Cutting grader blades
    Ok so i was wondering what is the best way to cut grader blades. Coming up starting a project that will take many cuts. Was using a old chop saw but it takes forever so i was wondering if there was a better way. These cuts also need to be weldable without too much grinding. Thanks.
    Gabe
    everlast power arc 200
    lawn mowers
    1st choice, plasma cutter. Second choice, band saw. What size grader ?
    I have cut down a bunch of blades and buckets. I prefer plasma but on some big cutting edges I use o/a and clamp a piece of flat stock for a straight clean cut. The "blade" being the rounded structure I use strap steel that is clamped or tacked as a guide and use a plasma. I watched a farmer use a saws all but it took hours and a ton of blades. I would say a portable bandsaw if your working on a garden tractor grader but have never worked on any that small so thats just a guess.
    ok. Ill just take the blades to school and use the plasma there then. We got a band saw there too but dont think it works. Im just cutting them to length and making a big box wedge out of them to put on a log splitter. My guess was either plamsa or a slow cut saw would be the best. At home only got chop saw and o/a and partner quickie saws which might be the best yet. Im not sure. My uncle tried o/a on one and just make a mess so went to chop saw but it takes forever so going with plan C now.
    Gabe
    lawn mowers
  1. Band Saw Blades what do you recommend?
    By Kendall in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 02-03-2013, 03:23 PM
  2. DIY dryer for plasma cutting and TIG welding. Dross cutting or TIG electrode fur
    Last Post: 03-15-2012, 01:08 PM
  3. Gravel Grader
    By dirtyfarmer in forum Other Custom Fabrications
    Last Post: 03-04-2011, 07:11 PM
