Results 1 to 20 of 29
Thread: A "Shocking" question....
  1. Default
    Are you using a high frequency arc starter such as for TIG, or are you scratch starting TIG or stick?
    You may need to look at a better glove for the welding hand, and better sleeves for the arm.
    Regardless, a better "picture" of the situation will help us make a better determination of what's going on.
    Quote Originally Posted by parkour View Post
    Yes... Tig, HF start for both welders and running in AC.
    I ditched the basic jacket they give you at school and bought a nice heavy jacket. The glove are Revco Tig gloves, pretty thick.
    I have been wearing long sleeve shirts and also have the welding jacket on. I just feel a slight "zap".
    I ground the table to the side and have been mostly practicing on Aluminum.
    The welding table I built at my shop has a ground tab under the side of the table to keep the clamp out of my work area...BUT, I was also going on the thought that you just ground the table to the side. Shouldn't a "teacher" know these things!? lol
    Are you on concrete when you get zapped? Also, are you perspiring in the jacket or gloves? If you give a path, does not matter where the clamp is, it will use you as the path.
    http://www.everlastgenerators.com/fo...ighlight=sweat
    Yes, I am on concrete both places.
    Not sweating at all.
    I've seen people ground their table using a short wire... Their thinking is electric will take the shortest path!?!
  3. Replies: 11
  4. Cutting 3"x3"x3/16" Angle
