Results 1 to 12 of 12
Thread: Powertig 250 EX on it's way.... Electrical question?
    Default Powertig 250 EX on it's way.... Electrical question?
    #1.
    Doe's the PT 250EX come with a plug attached or just a length of wire?
    #2.
    If just wire how long is the lead?
    #3.
    Also, Can I take the welder apart to remove the cord that is on it and ad a longer length of wire without voiding my warranty?
    My plug is in the corner of my shop and I need the welder to be able to cart out about 12'-15'. And after typing all this, I'm thinking it might be just as easy to make/buy an extension cord! Duhhh....
    I don't remember the length of the cord but I think it's about 12'. It comes with a little chincy 110V plug but it's not connected (toss it). Get yourself a NEMA 6-50 Plug and do it right. Of course a NEMA 6-50 outlet would be ideal.
    There are four wires coming out of the cord. If you are using 240V single phase tape back the red wire. Green is the ground and the others are for the other prongs.
    If you are using three phase power then you use the red wire.
    I made up a 25' extension cord using heavy gauge wires. It's costs about the same as the others that you see advertised on the internet.
    All this stuff is available from Home Depot of any other quality hardware store.
    Millermatic Mig Welder
    Gas welding setup
    A bunch of Snap-On tools
    And a Brain
    HI CGCINC
    I can tell you my PM256 came with a cord attached and a separate plug. The plug I did not use as it was not a standard welder plug. I bought a welder plug and receptacle from Home Depot. As far as making your own extension cord here is what I did. When I built my cart I attached the extension cord to it with two receptacles there. This allows me to have my tig and mig welder on the cart plugged to the cart. I can now wheel the cart around my shop or outside and use either welder for a project. You will also need to attach your gas bottles on the cart too. Use big back wheel where the bottles are attached. Put a draw on it for you consumables, collets and cups ect. Look around there are many different carts that have been made pick one that fits your needs. Some have a water cooler attached too.
    Have fun
    Tom
Name:	welding cart (1).jpg
ID:	3734   Click image for larger version.
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    There is alot of extension cords on ebay you might want to checkout cost might be the same as building one from home depot copper pretty pricey right now food for thought
    Ok, Thanks for the help.
    If it's 12' then that should work fine. I have a 6-50 plug to attach to it, just wasn't sure if it already came with the welder.
    I ordered the 250EX, W300 cooler and the powercart for it all so for now I will be using that cart. I do plan on making a bigger cart next spring when I order my Plasma cutter.
    My stuff should be here Thursday and I am so fired up to get it!! I CAN'T WAIT!!!!
    I've got a friend that works at a local electric supply company so I get most of my electrical at a pretty good discount!
    a bigger electrical supply house will have much better prices on cable. I paid $115 for 50' of 8-3 SEOOW (600v, neoprene jacket). lowes and HD don't carry service cable that heavy around here, and I'd wager it'd be over $200 for the same cable if they did.
    The two supply houses around here are summit and dealers. Summit is national, i think, but I don't know about dealers.
    McGuire Irvine
    Crow Motor Co.
    Lincoln powermig 225 (work)
    I'm sure you came across this all ready. Download the manual from this website. The one that's in the box is worthless unless you wan't to learn Chinglish.
    Gas welding setup
    And a Brain
    lol... First I need to learn Spanglish!
    CGCINC
    you already know Russglish
    Oleg Gladshteyn
    I managed to go the easy route. When my welder came in I was in the middle of having the garage wired. I told him what plugs I wanted where and had him add the matching plugs to my welder and my compressor.
    Everlast Powertig 225LX
    Harbor Freight O/A rig
    60 gal air compressor
    Everything you need to know is in the manual.
  1. PowerTIG 210EXT 2015 Model Question
    By Baronsbest in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 05-26-2016, 04:08 PM
  2. PowerTig 200dx question
    By AnimalMother in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-25-2016, 01:44 AM
  3. Powertig 185 Torch and pedal question
    By choppadude in forum General Welder Questions
    Last Post: 02-08-2015, 11:59 PM
  4. Electrical Question for EL Tech Guys
    By RP62 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-30-2012, 09:17 PM
  5. PowerTig 225LX question
    By alexm in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-04-2010, 02:13 AM
