Results 1 to 17 of 17
Thread: Please explain rod size and usage ?
eyspy Please explain rod size and... 10-14-2011, 10:15 PM
I_Love_Plasma Well the member "Geezer"... 10-14-2011, 10:31 PM
DaveO Another good source of... 10-14-2011, 11:06 PM
ogorir there's a chart on Jody's... 10-14-2011, 11:23 PM
eyspy Thanks for the response's so... 10-14-2011, 11:28 PM
jerky what kind of rod are you... 10-14-2011, 11:29 PM
undercut More info on welding on... 04-28-2012, 03:21 AM
Rodsmachineshop http://www.hobartwelders.com/e... 04-28-2012, 03:22 AM
I_Love_Plasma Personally I like 7018 low... 10-14-2011, 11:36 PM
ogorir also, this site is... 10-14-2011, 11:46 PM
SeanMurphy265 If I weld on galvanized I try... 10-15-2011, 12:42 AM
DaveO In case it becomes useful... 10-15-2011, 01:27 AM
geezer That pretty much sums it up,... 10-15-2011, 03:58 AM
DaveO I saw that welding.com.au... 10-15-2011, 11:54 AM
eyspy I'll be buggerd !! I have... 10-15-2011, 09:55 PM
    If I weld on galvanized I try to grind the area I'm welding. I try to get rid of the galvanizing or at least as much as possible. 6010 would probably work pretty good since that's considered the dirty, greasy, painted steel rod.
    In case it becomes useful information, in another post Eyspy said he has a PowerArc 200. The max recommended rod size for this machine is 3/16". As a reminder, 3/16" converts to metric by multiplying by 25.4:
    3/16" x 25.4 = 4.76mm
    This is assuming the technical specs of the Australian machine are identical- I seem to recall there were some minor differences between machines sold here and machines in Australia.
  1. MTS 250S Features Usage
    By colddainhell in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-29-2014, 12:27 PM
  2. Replies: 26
  3. Can anyone explain the PP205 Foot Pedal
    By Buggy Chief in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-05-2012, 01:12 AM
  4. Shielding Gas Usage Question
    Last Post: 05-04-2011, 03:56 AM
  5. collet size vs tungsten size
    By docweathers in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-08-2011, 03:31 PM
