I'm gonna go with sportbike on this one. The only time I have ever seen tig rod alloy matching the original base metal is the A356 rod that I paid $33.00/lb for to weld up an aluminum casting. I'm wondering if you could post pictures of your variable speed feeder with the hand-held end. I can see where if I could make something like that up, I'd end up using it more often than not.
Harbor Freight has a cheap wire feeder that is readily adaptable to Tig. They call it a Mig Welder though .
Thurmond
