I have contacted Duncan but wondering if anyone else has ideas?
I bought a pp50 and it worked great the first 3 or 4 times. When I try to
use it now, I can't get an arc or air when facing the cutting surface. If I
hold the torch up it works the second you tilt it, nothing. Air is at 90psi
out of the compressor and I have tried all pressures at the machine.
Replaced all consumables and it still only works pointing straight ahead.
Any ideas?
thanks
Alex, when you have overstock give me ring!
fyi I'm not part of the Everlast Team. I have some experience in plasma cutting, welding, electronics.. Just a helpful member like most members here on the forum.
